Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > bigben617
Total Load Control!
tonneaucovered.com
Conversation Between bigben617 and Rockstar 414
Showing Visitor Messages 1 to 6 of 6
  1. Rockstar 414
    08-16-2011 09:17 PM
    Rockstar 414
    Thanks for taking your time and checking that out for me I understand better now what that means.
  2. bigben617
    08-16-2011 02:04 PM
    bigben617
    OK. I went to the K&N site and looked at the instructions for your CAI install. It looks like your tube mounting bracket either installs to the cylinder head (where the negative battery cable attaches to) or the intake manifold (where the resonator attaches to.) It says if you have the air injector valve, connect the bracket to the intake manifold, if you don't ,connect it to the cylinder head. It seems like the air injector valve would be in the way if you were to try and bolt it to the cylinder head, so it should be self-explanitory. Hope this helps.
  3. Rockstar 414
    08-15-2011 04:44 PM
    Rockstar 414
    Ok, thanks for putting up the picture it does give me a better idea how everythings looks and thanks for the help. Can't wait to see what your new hood scoop will look like.
  4. bigben617
    08-15-2011 09:37 AM
    bigben617
    I changed my avatar to a picture of my Cold Air Intake, I don't know if this helps you or not...?
  5. bigben617
    08-15-2011 09:02 AM
    bigben617
    I see that you have a 2004 Ram, mine is a 2010. I'm thinking that the installation is different for our engines. The only brackets that I used on my install were the two that hold the heat shield to the fender well. My instructions didn't say anything about air injection value. Sorry I couldn't help you on this.
  6. Rockstar 414
    08-14-2011 08:40 PM
    Rockstar 414
    I see you have a K&N CAI. I just got one for my truck and in the instructions is says to use the tube mounting bracket and saddle. My question is it says to use one type of bracket if you have a air injection value and use the other bracket if you don't. How do I know if I have an air injection value?
