DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum (http://www.ramforumz.com/index.php)
-   Custom Dodge Ram Interior and Exterior Lighting (http://www.ramforumz.com/forumdisplay.php?f=78)
-   -   Mod #5 LED Tails and Turns (http://www.ramforumz.com/showthread.php?t=147518)
ShawnC13 04-02-2012 11:18 PM
So I had already done the back up lights and then wanted to do the brake lights so that is what this is about. First make sure you get RED LED's otherwise I a white would shine right through the lense.
http://www.ramforumz.com/PHOTOPOST/d...dium/Tails.JPG
All was going great brake light worked then the next day drove to work and turned on the signal.
http://www.ramforumz.com/PHOTOPOST/d...m/LED_Tail.JPG
I got 3 regular flashes then HYPERFLASH. So with the help of the guys on here they lead me to the right Load Resistors. 6Ohm 50 Watt. I got 4 off of ebay for 15 bucks.
http://www.ramforumz.com/PHOTOPOST/d...m/Load_res.JPG
The load resistors on the right rear go on Black and Wh/Yl and on the left it is Black and Wh/Gr. Even after reading this I put the left on the white yellow and knew as soon as I got the hyper flash what I had done. So now I am one splice cap short for the fronts when I do them.
