DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum (http://www.ramforumz.com/index.php)
-   Custom Chassis - Drive Line - Suspension - Wheels and Tires - LEVELING (http://www.ramforumz.com/forumdisplay.php?f=261)
-   -   295/60/20 Terra Grapplers (http://www.ramforumz.com/showthread.php?t=151050)
towboater 08-21-2013 06:01 PM
So I'm really interested in the above mentioned tires, but after doing a little research the weight thing is kind of putting a damper on this the idea. After a little digging I found that these things are 33 pounds PER TIRE heavier than stock. My question is how much will I notice in the seat of the pants feel when upgrading to these? My truck is a '13 Big Horn Crew, 4x4 and I'm running the 3.92 gears. ANY input on this would really help. Considering running this with a leveling kit but this entire tire thing is really aggravating.
brandonjansen 08-21-2013 06:08 PM
Go for it! The power loss is not near as bad as you would expect. Especially since you have 3.92 gears. I'm running 35x12.5 Toyo MT's which are a lot heavier than the Terra Grapplers with a 4.7 and 3.55 gears and the power loss was a lot less on that. You notice it a bit starting from a dead stop, or going up some steep hills. But other than that it doesn't bug me at all. Definitely worth it for the look.
Kcbigbadram 08-21-2013 06:21 PM
i ran them on my 2011 sport with bilsteins maxed. i honestly didnt notice any difference at all, and i only had the 3.55 gears
also they were on 20x10 rockstars not sure that it matters but just putting all the info out there
towboater 08-21-2013 06:27 PM
Thanks for the replies guys, and the more the better.
Jakebrake 60 08-22-2013 10:08 AM
I would have to agree with all the comments. I am running 315/70-18 terra grapplers and there is no problems
Imakebrakes 08-25-2013 11:16 AM
:smileup: Go for it !!!!
