DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum (http://www.ramforumz.com/index.php)
-   Exhaust (http://www.ramforumz.com/forumdisplay.php?f=141)
-   -   Stock 07 Exhaust (http://www.ramforumz.com/showthread.php?t=152305)
Arnesto 09-05-2013 08:02 PM
Stock 07 Exhaust
Hey there,
I did a search and couldn't find the answer to my question, also a google search couldn't really help either to what I think is a pretty simple question..
I have an 07 1500 Sport. I want to put in a flowmaster 40, but I see ones with dual in single out, single in single out... I know it's 3" in diameter. My question is does it matter if I buy a dual in, single in, etc.? What is the stock in/out on an 07?
RogerRamJet 09-05-2013 10:23 PM
Can you look up under your truck and see what you have?
I deleted my Y pipe and got a DI/DO.
compressor man 09-08-2013 08:12 AM
The inlet to the muffler is 3" and the outlet is 3", if you are keeping it stock and just replacing the muffler you need 3"SI/3"SO. Now if you buy a muffler that can be reversed, you can cut out your Y pipe and run 2.25"DI/3"SO, that will eliminate the restrictive Y and run the mid pipes straight to the muffler so the muffler becomes the Y pipe. I you want loud and cheap, I removed the muffler and ran just the rear resonator on my 07 for a short while, it sounded pretty good but was quite loud.
06 BigHorn 09-08-2013 09:13 AM
I did a single in/Dual out on my old 06
Inlet
http://www.ramforumz.com/PHOTOPOST/d...z_sdc10018.jpg
Outlet
http://www.ramforumz.com/PHOTOPOST/d...z_sdc10017.jpg
Tips
http://www.ramforumz.com/PHOTOPOST/d...z_sdc10015.jpg
Arnesto 09-09-2013 09:49 PM
Thank you all! Big help. I looked underneath it is single in single out, center on both. Thanks again!
