DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum (http://www.ramforumz.com/index.php)
-   2011 Dodge Ram Forum (http://www.ramforumz.com/forumdisplay.php?f=117)
-   -   Coolant leak (http://www.ramforumz.com/showthread.php?t=160098)
2011bighorn 12-05-2013 11:18 AM
Coolant leak
Hey guys just posting about my current situation. I have had a coolant leak off and on, on my 2011 1500 bighorn. I took it to dealer for oil change and asked them to check it out. They said we see old dried coolant nothing new. They put the due in and told me to come back the next day. I go back they pressure test it and can't get it to leak of course. They told me we see a small spot where it might possibly be coming from. They order a new water pump gasket and tell me they will call when it's in. That was the 23. I gave them until the 2 of dec due to holiday and called back because now when I start the truck first thing on cold mornings, it leaks like a bastard until truck gets to operating temp. They had me drop the truck off last night to see if they can get it to duplicate the issue I describe. The think the water pump has a small weep hole in it that closes when it gets warm. And I course the water pump is on national back order for Chrysler. They haven't called yet to tell me what it exactly is yet it will repost when I find out.
whatroads 12-05-2013 01:46 PM
Hate to say this......If there is coolant coming form the weep hole you have a dead water pump
2011bighorn 12-05-2013 04:14 PM
They replaced the gasket and said it didn't look like there was anything wrong with the pump itself. Tomorrow morning will be the ultimate test when it sits over night tonight in cold temp then is started. They also replaced thermostat because they said it looked like it had a little leak around it too.
gcscott 12-06-2013 10:13 AM
If you have coolant coming out the weep hole on the water pump than the bearing shaft seal is bad and the only fix is a new water pump.
Greg
Dancianne 12-10-2013 06:17 AM
Water pumps
I've owned lots of different vehicles over the years and of them all, only two have leaked as you've described,...both times it was a water pump gone bad. The puzzling part here though is that your truck is an '11. The two leaks that I experienced were on vehicles with over 150k miles on them. But, if there's a national backorder situation, then for sure sounds like a defect issue with the water pumps.
bartlett 12-10-2013 08:32 AM
Cold leak is very common in water pumps. The shafts shrink from the cold and leak. the weep hole is a built in fail safe. It is designed to let the water past the first seal and the leak is to tell you the water pump is about to fail.
To me it sounds like the dealership is stalling because they cant get the water pumps.
huntergreen 12-14-2013 09:47 PM
should be able to upgrade with aftermarket. thats what i would do.
2011bighorn 12-17-2013 09:41 PM
So they replaced the seal was good for 2 days then I started smelling coolant and I knew it wasn't the old coolant burning off the engine because I had already driven 120 miles and smelt nothing. I pop the hood and it is spraying of a hose. My truck started over heating. Took it back to the dealer and they said one of my hoses had a huge hole in it. They replaced and an no more leaks. I'm trying to get the wife on board with trading this thing in before more problems pop up. Only have 8000 miles left on 3yr/36000 warranty.
Dancianne 12-18-2013 11:14 AM
trade?
Wow,...surprised that your dealer did not catch some indication of an impending hose failure before this ! Just me, but I'd start having my truck serviced at a different dealer in the future if you don't trade off. Think I'd also change the oil now if your truck has overheated, those molecules don't reconstitute back in the same way.
huntergreen 12-18-2013 11:48 PM
agreed, you need a different dealer.
