DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum (http://www.ramforumz.com/index.php)
-   Dodge Ram Aftermarket Brakes (http://www.ramforumz.com/forumdisplay.php?f=267)
-   -   Differential c clip (http://www.ramforumz.com/showthread.php?t=172151)
mbobbish 03-30-2014 06:59 PM
Differential c clip
First post, hello everyone.
I have researched enough to find a notorious problem with the c clip(s) in the rear differential. While trying to diagnose a problem with extreme vibration when braking (already replaced rotors, pads, front calipers and hubs), I noticed about an 1/8" in and out play on rear passenger shaft, not so much or as obvious on drivers side. My question, is this normal, could it be caused by the clip, anything else?
Thank you in advance for any help.
RogerRamJet 03-30-2014 11:54 PM
Yes, it could be and probably has been caused by the clip. I had to replace my rear end because that clip tore it up. You'll probably have to do the same.
stratotrev 03-31-2014 05:29 PM
Sounds like what my old 2004 was doing very shortly before the rear diff went and had to be rebuilt. And you're right, it is an ongoing problem. Happened twice in 2 years, both times requiring a rebuild which prompted me to get rid of it and move on to something newer. Good luck, hope one fix gets it done for you so you can enjoy that truck.
huntergreen 04-08-2014 11:47 AM
thought the clip was only a problem with the lsd in the 04 years. am i mistaken?
starquestbd22 04-14-2014 02:03 PM
I'm pretty certain the c-clip issue affects any third gen truck with the 3.92 LSD. I would recommend that owners of these trucks follow the harsh maintenance schedule in regards to the rear diff so that they get a look in there every 15K miles. It really isn't that difficult and it could save a bundle of cash if you catch it early. If you don't catch it in time, you could be faced with replacing the entire rear housing and differential unit. Another good option is to go with an aftermarket LSD.
RogerRamJet 04-15-2014 01:34 AM
Excellent advice and very true.
