DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum (http://www.ramforumz.com/index.php)
-   Dodge Ram Wheels And Tires (http://www.ramforumz.com/forumdisplay.php?f=129)
-   -   Mystery leaking tire: Need suggestions (http://www.ramforumz.com/showthread.php?t=172617)
Bry 04-03-2014 09:25 PM
As the title states, I have a mysterious leak in one of my tires.
2 days ago, I had new aftermarket rims and tires installed. For the first 24 hours, there were no air pressure related problems. I did have a balancing issue that was sorted out yesterday. This morning I woke up to a flat front passenger side tire. I re-inflated the tire to it's recommended pressure (44 psi) and checked the entire tire for punctures. Nothing.
6 hours later, I was able to take the truck to the local automotive facility. By then the tire had lost 12 psi.
With the wheel still on the truck, they inflated and sprayed a soapy water mix every where: treads, sidewalls, rim, and valve. Over 10 minutes, they found zero bubbles. So they took the wheel off and threw it in the tank. Again, they found nothing and had no explanation for why it was leaking. The did tighten the valve core, or tried to.
It's been 4 hours since I left the shop, and the tire has lost 8 psi. So the leak is a steady 2 psi per hour.
If it helps, the truck has been driven about 40 miles in the past 2 days, has hit zero potholes, or anything that could potentially bend the rim and did not start leaking until some time last night (assuming the current 2 psi/hr leak).
Have any of you ever encountered a situation like this, or point me in the direction of a solution?
GTyankee 04-03-2014 09:36 PM
I had a similar inflation issue, not quite that much loss in pressure in such a short time
The problem was only solved when i exchanged that tire & wheel for different ones
The only difference that i can see between those & a Ram is that if you have a Tire Pressure Monitoring System on your Ram, could it be causing the leak ??
Bry 04-03-2014 10:22 PM
With that amount of air loss, I am literally shocked that A: you can't audibly hear the air coming out, and B: it's not producing any bubbles with both the soapy water, and the dunk tank.
Good question with the TPMS. I did not have the sensors transferred over from my OEM's because the aftermarket rims and tires came mounted from the business I purchased them from, and forgot to mention that I even needed TPMS sensors during the ordering process.
Aggie86 04-04-2014 09:12 AM
Cant answer why you dont see any bubbles but would highly suspect a leak in the wheel itself. Ive seen them be defective from the factory a few times in the past.
Bry 04-04-2014 09:35 AM
I'm preparing for that to be the case. I'm going to try a different tire shop to see if they also can't locate the source of the leak. I'll have them check the regular spots as well as taking the tire off and checking the bead, the seat, the inside of the rim. If they can't find it, I'll pursue a warranty claim.
Thanks for both responses!
jlc41 04-04-2014 10:50 AM
Have them go to 60lbs psi and tank the tire and wheel see if that shows the source of the leak. Good luck.
LowUFO 04-04-2014 08:07 PM
Yeah, I agree with this. The reason it's not showing in the tank is because there isn't enough pressure on the tire without the weight of the vehicle on it. 2psi per hour loss on the truck is going to be nothing off the truck. Raise the pressure and try again.
Bry 04-12-2014 04:51 AM
Updating...
Took it to a few shops last week. NAPA, Tuffy's, and a local garage, wouldn't touch it because they didn't want to screw up a 3 day old 24" rim. Fair enough, I guess. I respected their decision.
Goodyear OTOH, had no problem taking it in. They found a small puncture in the tire, and only found it by taking the tire off the rim. They weren't sure what caused it because there wasn't a foreign object embedded in the tire, however they showed me the puncture and it wasn't much bigger than a pin hole. Patched and plugged it. Fixed. However, they beat them rim up pretty good. They are paying for the rim to be repaired, and referred me to a company here in Tampa that does it. Bitter sweet.
Thanks for the help Z!
jlc41 04-12-2014 11:45 AM
Glad you got it fixed. I don't understand plug and patch. I thought you did either not booth. I would think the plug would interfere with the patch???
GTyankee 04-12-2014 04:33 PM
That method confuses me also
Although now, it seems that most every tire store chain is told to do both
No one uses what are called HOT Patches any more, they were mostly used on tire tubes
The theory now is, if you place a patch on the inside of a tire, water can still enter through the exterior hole of the puncture & therefore have access to the metal banding in the tires core & over time rust that metal. Rust would cause separation of the metal bands & the rubber
Plugging would fill the puncture hole & keep water away from the metal bands
?? Possibly the patch on the inside keeps water/moisture from entering the puncture from the inside, therefore again protecting the metal bands ??
Air that comes from a compressor would always have a small amount of water & compressor oil in it, even if you have a water separator in the line, that may be why everyone seems to be pushing the use of Nitrogen in the tires
:4-dontknow:
