DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum (http://www.ramforumz.com/index.php)
-   Custom Chassis - Drive Line - Suspension - Wheels and Tires - LEVELING (http://www.ramforumz.com/forumdisplay.php?f=261)
-   -   Leveling Kit Height Question (http://www.ramforumz.com/showthread.php?t=173389)
Cnorth1560 04-12-2014 12:30 AM
I've done a little research but haven't been able to find an answer. With a front 3" leveling kit spacer, will I need to install longer shocks as well?
brandonjansen 04-12-2014 01:31 AM
Your truck is 2wd obviously? Yes you will want to install new shocks with the 3" spacers or you will have a very rough ride as the shocks will be pretty much fully extended at normal ride height.
Cnorth1560 04-12-2014 10:47 AM
Thanks man. I appreciate the advice. The rake on this thing is horrible! The front is 3 1/4" lower than the rear and I feel like I'm sliding out of my seat...
Spaightlabs 04-13-2014 10:35 AM
If you boost the front 3 inches and put some weight in the back or on the hitch and youwill feel like you are looking at the sky...
Cnorth1560 04-13-2014 01:54 PM
Yeah I knew that would happen so I installed the leveling kit yesterday and ordered a Firestone air spring kit this morning. I went ahead and reused the factory shocks and it seems to have the same ride quality as before and I really love the look now. It's is perfectly level. Maybe now I will be able to see down these backroads with my low beams...lol.
