DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum (http://www.ramforumz.com/index.php)
-   Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD (http://www.ramforumz.com/forumdisplay.php?f=24)
-   -   2010 spindle help (http://www.ramforumz.com/showthread.php?t=62395)
mattsRAM 09-26-2010 10:17 PM
2010 spindle help
Need help. I have dropped my ram in the rear but I now need to drop the front using spindles. I have never done this before and the instructions are crap. Has anyone done this before? I would like to have pics too. I know I can do this in my garage but is there any tricks or suggestions?
moparornocar72 09-26-2010 10:28 PM
Just be careful and if you are doing it your garage make sure you have good jack stands. Hope this helps:
  1. Raise and support the vehicle.
  2. Remove the wheel and tire assembly.
  3. Remove the brake caliper and rotor.
  4. Remove the ABS wheel speed sensor if equipped, Remove the halfshaft nut.
NOTE: Do not strike the knuckle with a hammer to remove the tie rod end or the ball joint. Damage to the steering knuckle will occur.
  1. Remove the tie rod end nut and separate the tie rod from the knuckle using Ball Joint Remover 9360.
  2. Remove the upper ball joint nut and separate the upper ball joint from the knuckle.
http://alldatapro.com/alldata/PRO~V1...2604/150786718
  1. Pull down on the steering knuckle to separate the halfshaft (2) from the hub/bearing.
  2. Remove the three hub/bearing mounting bolts (1) from the steering knuckle.
  3. Slide the hub/bearing out of the steering knuckle.
  4. Remove the brake dust shield.
That's all I can dig up for now. Try getting on the manufacturer of your drop kit and see if they have specifics. again hope this helps, let me know if there is anything else i can try to help you with
moparornocar72 09-26-2010 10:29 PM
note also sometimes alldata changes there coding and the images shift so if it changes let me know
moparornocar72 09-26-2010 10:30 PM
heres the caliper and brake housing/hub
http://alldatapro.com/alldata/PRO~V1...8158/150901617
BigHorn 4 Life 09-26-2010 10:37 PM
Can you raise your truck like that too?I need 1.5 more inches :).
mattsRAM 09-27-2010 12:03 AM
Thanks a lot! That was a quick response. I will try tomorrow and will let you know shortly after with the results.
Thanks again for the info...
moparornocar72 09-27-2010 06:09 PM
anytime! keep us updated!
sowardcustoms 09-29-2010 06:41 PM
Hey Matt I did my 2010 in the driveway its pretty straight forward I did one side at a time its alot easier then putting springs in and because both ball joints are pointed the same way the spindle comes off with ease...here is a pic with the spindle off.....
http://www.ramforumz.com/showthread.php?t=50007
