Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 04-25-2011, 12:51 PM
sonocativo's Avatar
Color: Electric Blue
Rep:215
Default Weight Limit
I am trying to figure out what is the weight limit I can haul in the bed of my truck. I am having a retaining wall put up this weekend by some friends since I cannot do the work due to spinal injuries and surgeries, I am needing to haul rock/sand.... I did 1 scoop of sand ( 3 cubic yards ) at 1750 pounds and it took the rear of the truck down 1/2 way what the unloaded distance of the wheel well to the tire was...
Here is the specs on the door tag for any info needed to calculate...
1500 club cab, short box,4x4,360...
Date of Manufacture 4-97
GVWR
2903KG ( 6400 lb. )
GAWR
Front 1747KG ( 3850 lb. )
Rear 1633KG ( 3600 lb. )
3500 front axle Dana 4
Rear chrysler 9.25
Thanks for your help on this info.......
Mike
Old 04-28-2011, 05:27 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
This is a quote from GTYANKEE:
"go to this website & follow all the prompts for your vehicle
http://www.dodge.com/bodybuilder/year.pdf
look at the tire sizes & other things too, when you get to the load, trailer towing part
like in my '09 ram 1500, i can put only 1570 pounds in the empty truck, that is counting people, beer, cameras, etc
then i can put 6,700 pounds on the trailer hitch, that is everything, empty trailer, beer coolers, empty cans "
In my 2010 with the 3.55 gears as equiped I can only put 1300 pounds in the empty truck.
Sounds like an overloaded situation you had before.
Old 04-28-2011, 06:41 PM
Rep:2664
you figure your payload weight by
Payload
The sum resulting from subtraction of the curb weight from
the gross vehicle weight rating (GVWR).
1997 Dodge Ram 1500 2 wheel drive 4X4 weigh more, thus can haul less
Weights: gross vehicle weight rating (kg) 2,903 (6400 lbs), curb weight (kg) 1,833 (4041 lbs), gross trailer weight braked (kg) 1,633, front axle weight (kg) 1,656, (3651 lbs) rear axle weight (kg) 1,769 (3900 lbs) and max legal load (kg) 1,075 ( 2370 lbs)
My math may be wrong & the website that i got most of the info from may be incorrect
1000 lbs is 1/2 ton
1500 lbs is 3/4 ton
2000 lbs is 1 ton
Old 05-05-2011, 07:36 PM
sonocativo's Avatar
Rep:215
Thanks Guys, Well, at least I know I am in the safe limits...
Mike
Poll on oil weight you use in your 5.7 Mcbride 5.7L (345 cu in) HEMI V8 Specific Topics 45 02-27-2012 07:23 AM
Tire weight differences? snrusnak Dodge Ram Wheels And Tires 5 04-16-2011 03:30 PM
Max Towing Weights for the 1500 Bellzy Towing 4 03-23-2010 01:48 AM
