My truck will no cut off I can crank it up but it won't shut off. I have to pull the fuel pump Relay to cut it off. I've checked most fuses but I'm pretty stumped
Something wrong with the FOB ignition switch, that's all I can think of, if you pull your FOB and walk away and it keeps running its like the switch is staying in the on position not sensing the FOB is out. JAG
I had the same problem with my 2010 Ram, it would start and you could turn the key to off and remove it and truck was still running. If you inserted the key again and turned it to on then off it would shut off. Well long story short, it turned out to be the main fuse box. The dealer had to replace the entire main box. It worked after that but I had been having to many problems with that truck that I traded it in on a 2012 Ram Sport. I have only had one problem and it is being resolved now, needs new light switch.
Related Threads
DODGE RAM FORUM
2.2M posts
201.9K members
Since 2008
We’re the ultimate Dodge RAM forum to talk about the RAM 1500, 2500 and 3500 including the Cummins powered models.
