I have a 2006 dodge ram and the interior lights will not stay on unless the truck is running. Normally when you open the door to get in the interior lights stay on until you close the door or start the engine. Lately when i open the door the lights will stay on for a few seconds and go off. I also noticed that if you push the interior light to turn it on manually it will no longer work once this has happened. Something else I noticed is when using the keyless entry to unlock the door the tail lights and headlights will flash and immediately go out instead of staying lit for a few seconds like they normally would. I checked the battery and it is good. Any suggestions?
