Hi- Looking to buy 2014 base tradesman v/6, but all in Portland Or seem to have 3.21 axle . I want the 3.55 for towing purposes .What is the practicality and cost of changing the gears ? Also , if not done by dealer would that affect the warranty ? Thanks
I think if the dealer did the swap, it would still be warranted. Are you sure that with the 8 speed trans you need the deeper gears? If you did 3:92's or 4:10's she could be quite a hot rod. You would need either the dealer set the speedo or buy a tuner, also. It's not a job for just anyone, setting up a differential requires a good mechanic.
yeah, I didnt wait for the 3.55 gears. I found a really good deal on a 2013 quad with 3.21 gears and got it. Wish I had the 3.55 but didnt wanna keep looking for trucks. I pull a 3500# 19 foot bayliner boat with mine and it tows it actually as well if not better than my 2003 4.7 v8 ram I had before. Revs a little more but doesnt ever seem to struggle. What are you going to tow with it? The main reason I would rather have 3.55's is because it likes to shift from 8th to 7th on the highway more than I think it should. Going up smaller hills, going into 10mph head winds. I get annoyed with the shifting and lock out 8th gear, which is fine with me cuz it still gets better than 20mpgs doing it. I would still buy the truck I have if I could do it over.
Thanks for the info . I'll be towing a 18' StarCraft which is 3500 lbs fairly empty . With a bed cap on the truck , 2 people ,gear , gas tanks filled etc will probably be closer to 4000 lbs easy . That seems a little too close to the 4800 lb max towing capacity of the 3.21 axle . Do you guys agree ?
Yeah if you're close to the limit I would get the 3.55 gears. I wouldn't mess with changing the gears unless its a 4x2. Too much cost and somewhere I heard the fronts are welded in. I guess you could bring the gear swap up when you're making the deal and see what they tell you.
Related Threads
DODGE RAM FORUM
2.2M posts
201.9K members
Since 2008
We’re the ultimate Dodge RAM forum to talk about the RAM 1500, 2500 and 3500 including the Cummins powered models.
