Hi
I have a 1989 dodge 150w 4x4 with the v8. The engine will always start but acted like it wanted to die out. It will run very smooth but acted like it was not getting fuel.
I first changed the fuel filter then the fuel pump. It was a tiny bit better but still stalls out after starting. If I pump the gas pedal it will run fast for a while and when I hold the pedal half way down it will run at high speed for about 20-25 seconds and then die right out and stall.
What would be the next part to change?
