Old 05-12-2014, 10:50 AM
Vehicle: N/A
Rep:338
TransEngineer is a jewel in the roughTransEngineer is a jewel in the roughTransEngineer is a jewel in the roughTransEngineer is a jewel in the rough
Originally Posted by Mudrakle View Post
I had a problem a few months back as well with my Transmission only shifting into 4 gear "limp mode". I took it to the dealership since I have an after market warranty on it. They had to replace the throttle body. It is a known issue and is covered under the power train warranty ( can't remember for how many years) I hope this may help someone.
I think you probably mean the valve body (not throttle body), but again please realize that there are many different things that can cause transmission limp-in (4th gear only), so you have to check the fault code(s) (and usually, run some further diagnostics) to determine where the real root cause is.
Old 05-12-2014, 06:50 PM
Color: green
Rep:621
standard powertrain warranty is 5 years or one hundred thousand miles.
Old 08-15-2014, 08:56 PM
Mrplow1965 Mrplow1965 is offline
Vehicle: 2011
Color: red
Mrplow1965 is on a distinguished road
Ok so I just recently purchased a 2011 ram 1500 and yep a day after leaving the dealer limp mode took it back with 2 codes po750 and po876 they had it 3 days and said they found burn wires on the right side of the motor repaired them reset the codes and I was good well as soon as I got in it took 10-15 seconds to engage in drive and when I kicked it down driving I thought it was going to fly apart drove it home and to work the next day still no codes or limp mode just slow to engage in drive the following day as I start it and put it in drive yep limp mode drove right to the dealer after 2 days called and they had it tore down and debris was in it new pump and clutches and the same codes as before after 6 days go to get it and didn't even make it to me went limp mode in transit to me so back to service where it is now with the same codes and come to find out they rebuilt the trans but never touched the solenoids at all will post as it plays out .........
2001 Ram1500 5.2 L Transmission shifting problems Mic Shaw 5.2L V8 Specific Topics 12 06-13-2011 08:29 AM
TRANSMISSION LOCKED IN 4th GEAR Studbuster 2009 Dodge Ram Forum 2 02-05-2011 08:21 PM
45/545 RFE Transmission Overview RamTech Dodge Ram Knowledge Base 13 02-04-2011 03:13 PM
Transmission wont go into gear 5.7L 5.7L V8 Specific Topics 18 12-07-2010 12:44 AM
Transmission has slight shift delay??? Quiet Lunatic V6 Specific Topics 5 02-05-2009 05:09 PM
