Ring and pinon question
962 views 7 replies 3 participants last post by  ScatPak07
#1 ·
I have a 97 Dodge ram 1500. I have a 5 in skyjaker lift 35 in tires on 15x10 wheels. I have a hypertech programer long tube headers air raid cold air intake and true dual exhaust with flowmaster super 40 mufflers. Is it worth going to a 4.56 gear. Im open to any suggestions out there on this supject or any more engine mods for more power.
#4 ·
Stock gearing can be one of several different ratios. You most likely have the 3.55's or 3.92's. If you have the 3.55 gears, I'd go with a 4.10 for a 35" tire, especially if you ever do any highway driving. If you have the 3.92's and it isn't enough, then consider the 4.56 gear set.
#5 ·
Alright cool I have 3.55 gear ratio. When I go to work I cruz around 60-65 mph. My only issue is I call 4wheel parts and they tell me 4.56. I watch an xtrme 4x4 on spike they did a ratio swap on a 97 1500 to a 4.10 gear and gained 3mpg so im kinda stumped on this cuz I get a diff answer everytime
#8 ·
Yea go wth a 4.10 gear that would be the better way to go. You will have more then enough gear to turn the 35s. I have 3.92s on my 07 with 35" tires and they work great together, so the 4.10s would be even better
