I'm trying to find a wire to tap in for an auto dimming mirror. I have tried tapping into the overhead console but I only have map lights. When I tap into those I can only get the mirror to work when the lights are on. Any suggestions on where to tap into?
Did you try to hook in to the power line going to the compass module (if you have it) I believe it is the red wire.. Use a meter or test light to make sure. You want to hook it up to something that gets turned off by the ignition key.
Andy
Related Threads
DODGE RAM FORUM
2.2M posts
201.9K members
Since 2008
