Ok so I was on here a while ago asking for wiring diagrams for these model trucks and yall were able to help me so I'm back with another question. First let me give you all an idea of what I am doing. I am taking the entire powertrain and suspension from a "10 Ram 1500 and putting it in an old F-100 that I have had for years. (Forgive me for dropping the f-word here).
To keep things as simple as possible I wanted to use a factory harness, including things like the factory fuel pump, ect. Now obviously not everything is going to plug in, but everything for the powertrain is good, the fuel pump, wheel speed sensors, abs all that good stuff. Now its time for me to get the ignition taken care of. I know that with ford's anti theft system the "PATS" code is programmed into the key to match the code in the ECU and gauge cluster. And finally I am wondering, for these new rams which components need to be from the same vehicle? Is it the ECU, the key module and the key itself? Or does the gauge cluster also need to be from the same vehicle?
I'm trying to remember off the top of my head which components have to be programed. I know the WCM/WIN and the PCM are a must but I'm not sure if the info is also stored in the TIPM along with the vehicle configuration.
Ok so the WCM/WIN that is the module that the key goes in, right? And I know that TIPM is the "total integrated power module" and that WCM is the "wireless control module" and that WIN with "Wireless Ignition Node". Correct me if I'm wrong but the WCM/WIN are the same thing with different name (the reason you put a slash between the two)? And lastly just so I can put a picture to a name the WCM/WIN is the little black box that the key FOB plugs into like an ignition key, right? Again I really appreciate your help. Once I get this truck running its really gonna be a unique and fun to pop the hood and show someone the Hemi under the hood.
You're right on all accounts. The WCM and WIN are the same thing but depending on what year it came from and who you ask, it could be either one. Perhaps when it's finished, you can make a custom decal for it that reads "Built Ford tough with Mopar stuff".
Ok one more question... for now anyway. If I get the ECU from one truck that was equipped with the same power train that I am using now and the WIN module from another truck will the dealership be able to program them to work together?
I've never tried programming components from two different vehicles like that, so I don't know if it can be done. I suspect in the worst case scenerio, you'd need a new WIN module.
Hey Ramtech, so I have another question for you. I found an ECU out of a 2010 Ram 1500 with the 5.7 and and automatic and I purchased it. Then I had a technician come out and try to program the key. He was telling me that everything was communicating just fine, however when it came time to input the pin codes with the associated ECU it wasn't working. They double checked that they had the right pin codes and I double checked that I had the right VIN from the truck that the new ECU had came out of. However for some reason it just wasn't working. So I went ahead and returned the new ECU and I am back on the hunt again for an ECU. I haven't had any luck finding one for a 2010 however I have come across one that came out of a 2012 1500 with the 5.7 and an automatic. Seeing that it is the same engine do you think I would be able to use the 2012 ECU for the 2010 powertrain? And again thank you so much for your time and assistance.
Related Threads
DODGE RAM FORUM
2.2M posts
201.9K members
Since 2008
We’re the ultimate Dodge RAM forum to talk about the RAM 1500, 2500 and 3500 including the Cummins powered models.
