Old 05-12-2014, 08:59 PM
Dragon21 Dragon21 is offline
Vehicle: 2009 Dodge Ram 1500
Dragon21 is on a distinguished road
Default Alignment issue? Pictures included
Been trying to figure out why I've had an issue with my tire rubbing my upper control arm ever since leveling and alignment. Found today that the eccentric bolts on the lower control arm are set different. On my driver side, both bolts are set the same. The passenger side, both bolts are different from each other, and different from the driver side. Is this normal? I thought Both sides should be the same.
Old 05-12-2014, 09:38 PM
Boosted's Avatar
Boosted Boosted is offline
Trim Level: Outdoorsman
Color: Black/Mineral Gray
Rep:219
Normal. The adjustment needed on either side to get proper alignment will vary therefore chances are the alignment cams will end up different.
Old 05-12-2014, 09:50 PM
Thanks, I just thought it strange that the driver and passenger side were 180* different from each other
Old 05-13-2014, 03:58 AM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default Get all proactive at the alignment
Get the alignment people to print out a screen shot of the final angle adjustments. No matter the look of the bolts, the laser guides make the tires get into alignments if the tech reads the screen
I go to a guy who gets all the stuff to within the tight tolerances. So get involved with your alignment.
Old 05-13-2014, 10:17 AM
Here is the alignment report. My camber looks to be an issue even though it's in "spec"
