Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 03-09-2014, 09:23 PM
startrek startrek is offline
Vehicle: 2014 2500 6.7 diesel
startrek is on a distinguished road
Default 2014 low power
Just traded a 2012 2500 6.7 cummins auto for a 2014 6.7 cummins auto, the 2012 was stock and would run circles around the new one, the new one has less than a 100 miles on it and I realize there is a 10,000 to 20,000 break in period however I have never had a new diesel that had such poor take off. Is this normal for or do I need to take it in for a check up?
Old 03-09-2014, 11:28 PM
semlohde semlohde is offline
Vehicle: 2014 RAM Laramie LongHorn Mega
Trim Level: LaramieLongHorn Mega
Color: bright white
semlohde is on a distinguished road
There was a test on the web of the 3 diesels I believe it was last year. RAM scored worst in mpg, pickup speed and a few other tests. My 2014 Megacab 2500 is a slug but if I can cruise at 60-65 empty I am hand calculating 19. Mine ran rough and I was disgusted with it but at 4400 miles it seems smoother. Still vibrates but smoother. MUCH worse than the 2011 crew or 2013 mega Laramies I had. But slow pickup, tested worse of the big 3.
Old 03-09-2014, 11:40 PM
dan15808 dan15808 is offline
Vehicle: 2014 Dodge Ram
Trim Level: Tradsman
Rep:19
dan15808 is on a distinguished road
Just curious, did both trucks have the same gear ratio? A lower gear ratio can have a big difference on takeoff and acceleration.
Old 03-10-2014, 05:45 AM
yes, gear ratios the same
Old 03-15-2014, 10:57 PM
Default low power
I stand corrected ,the 2012 was geared 3:73, the 2014 is 3:42, plus the 2012 had 17" wheels and the 2014 has 20" wheels that beat you to death by the way.
Old 04-01-2014, 05:37 PM
rickkimbrell rickkimbrell is offline
Vehicle: 2008 Ram 2500 Megacab 4x4
rickkimbrell is on a distinguished road
My 2014 2500 Ram (automatic) has 7100 miles on it. Traded a 2008 3500 Ram automatic for it. The 2008 had plenty of power both on take off and if you had to punch it at say 35mph. The 2014 is a real dog. Almost got hit today because someone was moving over on me and instead of braking I punched it...nothing absolutely nothing.
I am also having some transmission issues but it is between 2 and 3 gear so not on takeoff or not on rolling and punching it. So transmission is another story to be resolved hopefully.
Old 04-01-2014, 08:09 PM
Default me too
I understand, my 2014 automatic trans feels like it slips between gears on a light load, dealer said it's normal. But I do like the 20 mpg highway.
Old 04-04-2014, 08:38 AM
txcowboy69 txcowboy69 is offline
Vehicle: 2014 Ram 2500 diesel
Trim Level: Larami crew cab 4x4
Color: Granite
txcowboy69 is on a distinguished road
Startrec, I also have a 2012 cc 4x4 dully with the 3.73. it gets 11 mpg. just ordered 2500 cc 4x4 but I got the 3.42 and 17" wheels 6 speed trans. All this done before I found this web site. Now I wish I ordered it a little different but all I cared about at that time was getting away from the 11 mpg thing.
Old 04-13-2014, 01:49 PM
Default power
Changed from 20" wheel/tire combo to 18" , mostly to improve the ride but partially to see if the 20 combo was reducing take off power, did not make a hill of beans difference I guess since the 18" tires are only 1/4" shorter than the 20's. So I guess the 3.42 gears is what makes mine feel so much weaker off the line and with a load than my 2012 did.
Old 05-11-2014, 09:26 AM
MDN's Avatar
MDN MDN is offline
Vehicle: 2014 Ram
Trim Level: Limited
Color: Deep Cherry Pearl
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
MDN is on a distinguished road
After a long line of GM 3500's I made the switch to a 2014 Limited 3500 cc long box.
I cant be more happy with my truck. I will say that out of the trucks I test drove, I thought the 3.42 was more responsive and deceiving in speed. When I went to purchase one, I noticed it had 3.73 gears and felt really slow accelerating. I then opted for the one I have and it has 3.42 and with less than 1000 miles on it I am getting 18.5 mpg running 78 mph. My towing mileage is better than the 2013 Dmax as well. I never saw more than 10.5 and getting 11.5-12 hand calculated. So far no complaints.
m
2014 Laramie Longhorn Limited - Deep Cherry Pearl - Cummins/Aisin
