A few pics of the install of Code Alarm ca6551 alarm/remote start on my 07 Ram 1500 quad cab. Used a Flash Logic FLCAN to tie the whole thing together. Mounted alarm horn using existing mounting holes, hate to drill if I don't have to. Ditched the hood pin in favor of a mercury switch mounted to the hood, mirrored the hood light wire routing. Blue LED's are built in to antennae, will add that pic later after I learn better how to manage photo uploads.
Got the alarm and can module for $270. Install not too bad if you have done alarm/remote start work before. Hardest part is tying in to the ignition switch harness, have to be sure to use the correct wires as there are multiple wires with same color code in column. If you pre-wire the whole setup on the bench, it saves a ton of time working under the dash.
