Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.6 Liter Pentastar V6
Custom Dodge Ram Performance Mods - Engine - 3.6 Liter Pentastar V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 3.6-liter V6 engine - 305 horsepower, 265 lb-ft of torque.
United Radio
Old 08-18-2014, 11:54 AM
ksarnecki ksarnecki is offline
Vehicle: 2013 Dodge Ram 1500 4x4
Rep:29
ksarnecki is on a distinguished road
Default Looking into a Pro Comp 6inch lift and 35s
So I've recently came across this post and noticed it was a lifted pentastar.
http://www.ramforumz.com/showthread....ferrerid=73463
I'm thinking about doing this myself but just wanted some input. My only real hesitation (besides being broke after) is the 3.21 gearing my truck currently has. I was thinking about re-gearing, maybe to a 4.10 or at least a 3.92 but Im not sure where to go on that. I would install the lift myself but I am afraid to do any gear change on my own. I would be keeping my 18x8.5 Hollywood outlaws with +15 offset and putting on 35X12.5R18LT BFG Mud-Terrain T/A KM2s.
What do you guys think?
Old 08-18-2014, 11:58 AM
Rep:29
Any insight y'all have is appreciated
Old 08-24-2014, 08:20 PM
BrandonB's Avatar
BrandonB BrandonB is offline
Vehicle: No Ram
Rep:35
BrandonB is on a distinguished road
I wonder what type of experience people are having with the lifted Pentastars?
2006 1500 Sport 4x4, 5.7 Hemi - SOLD
Currently shopping for new Ram!
Old 08-25-2014, 12:44 AM
Lifted Cummins Fanatic
Rep:1990
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
I definitely wouldn't be running 35's on a pentastar with 3.21 gears. You'd want at least 3.92's but 4.10's would be better. But you can't change the gears in a 2012+ ram easily because the front ring gear is welded to the carrier. So you'll need to get a front diff from a 2011.
I would also recommend a Zone lift before a ProComp.
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2 | Mag-Hytec Rear Diff Cover | 5000K Morimoto HID's (lows and fogs)
Old 08-27-2014, 01:35 AM
Rep:29
Thanks for the insight. Every shop I have been talking to about the gears is saying the same thing and Ive had one or two that have found ways to do it, but getting quoted at just over 2k for the job This will probably not happen for a few years so hopefully there will be a better solution by then and with any luck I will have a 6.7 Cummins by that time instead!
Old 09-26-2014, 07:04 PM
00000 00000 is offline
Vehicle: 09 dodge ram 1500
Color: Austin tan
00000 is on a distinguished road
I had 35/12.50/17" tires on my pentastar and I was burning 25.5L/100km
Old 09-26-2014, 07:06 PM
Color: Austin tan
I have the 3.55 gears
Old 11-11-2014, 02:23 AM
stikystikyricky stikystikyricky is offline
Vehicle: 2013 Ram SLT Pentastar
stikystikyricky is on a distinguished road
What???? Thats crazy!!!
So you put 35s on you 3.6L pentastar ram and it dropped your fuel economy from 20+mpg to 11mpg?
Thats almost cut in half!! I expected a few mpg drop, not 50%!!
Good to know!
Can anyone else confirm this, because other threads I see differently and I WAS just a tad bit of research away from pulling the trigger on 35s..
Check out ThunderRams post in this thread:
http://www.ramforumz.com/showthread.php?t=170402
"ok heres the scoop!
truck has 3.55 Rear Axle Ratio
I Put 35x12.5x17 Dick CEPEK Radial F-C II with ProComp 7031 Flat Black Rims and a Front and back Ready Lift Leveling Kit
My fuel mileage did go down but not as much as i thought it would. I monitor my fuel mileage pretty close, its gone down about 3MPG also I dont drive the truck hard
I also have a before and after photo but im yet to figure out how to post it"
Old 11-11-2014, 04:01 AM
Rep:1990
Good to know!
I almost guarantee he didn't correct his speedo for the larger tires and was going off the EVIC so his 25.5L/100km is way out to lunch. I would definitely go with what you've seen in the other threads.
