So this is the installation of my Volant on my 08 Hemi.
Before:
Step 1: Disconnect negative battery cable.
Step 2: Loosen hose clamps on resonator box and stock air box
Step 3: Remove air hose from resonator box and stock air box.
Step 4: Remove breather hose from stock air box
Step 5: Pull out stock air box
Step 6: Remove grommets from stock air box and install in Volant air box
Step 7: Place Volant box where stock was and push down firmly. (I ended up breaking one of my plastic posts but it is still secure)
Step 8: Apply coupler to resonator box and firm up, do not tighten as it will warp the other end and create an issue connecting the air duct.
Step 9: Install Volant Air Duct to Volant Air box then slide back into coupler on resonator box, tighten clamp and install filter and tighten all 3 clamps. *Make sure opening for breather hose is in correct location
Step 10: Connect 3/4" elbow to air duct and connect breather hose to it.
Step 11: Place Volant cover on air box.
Step 12: Make sure everything is properly connected and all clamps are tightened.
Step 13: Re-connect negative battery cable
Complete!!!
Probably took me about an hour, but that was with also tracking down my tools that my two little helpers had * 7 year old son and 4 year old daughter*
Now to see how it will perform with my intune!! Next will probably have to be a Y pipe to let all this air flow out freely.
Before:
Complete!!!
