check on line and said it was oil pressure.mine is normal in the dash and the engine run great .what would be the problem
:4-dontknow:
i took of battery post and the light when off . going to have it check
Sometimes clearing the code is all ya gotta do. But, if it comes back then it's time to get whatever is throwing the code fixed.
It could be a sensor as was mentioned above
It could also be an oil filter collapsing, some cheaper common oil filters can do that
