i need to find out what wiring harness i need to install my after market cd player in my 2008 dodge ram 1500 4x4 big horn with the infinty sound system. im not sure if i have a factory amp
If you have the Infinity system you should have a factory amp, but you should look at the PAC audio harnesses; C2R-CHY4 if you have the factory amp, and C2R-CHYNA if you don't have the factory amp. If you have the steering wheel controls then you'll need to pick up the additional harness for that.
This adapter thing is confusing me also. I have a 07 1500 with basic stereo system(with the knobs) with only four door speakers... not even sure if I have an amp. I am installing an Alpine double din with nav but I have no idea which adapter I need. If I add an amp do I use C2R-CHYNA? If I don't add an amp do I still use C2R-CHYNA or do I use C2R-CHY4?
Related Threads
DODGE RAM FORUM
2.2M posts
201.9K members
Since 2008
We’re the ultimate Dodge RAM forum to talk about the RAM 1500, 2500 and 3500 including the Cummins powered models.
