I have started with a RC that sat after being traded in for 18 years before I bought it for $250 5 years ago
The engine has been swapped to a 97' 5.9 Mag with a carb for now
I've replaced every wearable item in the suspension & brakes & lowered it with Van LCA's in the front & an axle flip in the rear
Here's how it looked after the original 318 was pulled
Magnum with all the correct stuff to do the Magnum serpentine with A/C
The Edelbrock RPM which is the only intake that even comes close to doing the swap needs modification The heater outlet comes out under the A/C compressor so you have to drill & tap one
The kickdown cable kit & throttle cable bracket are from Bouchillion & allow use of my cruise control
In upgrading to the Mag motor I wanted to EFI it in the future & besides when you use the Mag serpentine drive system there's no provision for a mechanical fuel pump leaving the only other choice to be electric in line
The pump I chose was a Carter EP4070 the requires a 3/8"-#6 line
I needed to upgrade my fuel line & here's how I done it
I bent another pickup tube & put a bulkhead fitting in my tank close to the original sender
Knowing that some time in the future I was going EFI it needed done anyway
I cut a slot at the top of the original pickup so I could use it for a return line
One thing that I have learned over the last 30 years when drastically lowering or lifting a vehicle is that everything has to move
I have read hundreds of lowered threads & I seem to be the first to mention anything about moving all the E brake stuff when doing a axle flip
The simple relocation of the forward linkage & the cable bracket only requires redrilling three 3/8" holes almost 3" higher on the frame
The bracket is bolted on with 2 1/4" standoff style studs that incorporates the fuel pump mount that fits either a Carter or Aeromotive pump on the other side of the frame
The wagon is a 59K original & I've pulled the motor to detail under the hood along with changing over to Magnum heads & Purple Stripe cam
Ol' Frank,he came to town for guest appearances at World of Wheels & I heard he was trying to buy a dual four 59' Vette project
I waited at the end of the line & let him know he could bring that Vette by the shop that I had & I could either appraise it or buy it from him
My 84 will receive this crossmember 2 3/4" higher in the frame along with redesigned strut rods & a Rack & Pinion
The goal being 8" drop in rear & 6" front using mostly all stock suspension or Chrysler made parts while retaining a almost stock ride
Here's today's pic before I start disassembling it again
Sorry meant to get back with you but the truck sold pretty quick. I picked up a 93 long bed with a stroked 360 and 512 cam. Also fuel injected! Keep up the good work!
Well, there ain't but 2 Ramchargers in here, so I figured I'd better bump this & see how you're coming along!
Keep me up-to-date on your Magnum upgrades. I have the performance ECU for mine, so I can run a hotter cam & lifters now. I'm looking more for torque than anything else, though.
Related Threads
DODGE RAM FORUM
2.2M posts
202.3K members
Since 2008
We’re the ultimate Dodge RAM forum to talk about the RAM 1500, 2500 and 3500 including the Cummins powered models.
