Old 06-25-2013, 02:28 PM
haybo19 haybo19 is offline
Vehicle: dd69
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
haybo19 is on a distinguished road
Default Passenger side window button won't work... help plz
Picked up my new 2003 ram 1500 regular cab. I knew the window wasn't working before it was bought. I am just wondering if there is an obvious reason as to why the passenger side window button wont work on the passenger side. The window WILL go up and down if I use the driver side button, but will NOT work if we try the passenger side. Any help would be appreciated, not good with the electrical side of things.
Old 06-25-2013, 04:43 PM
davidgcet davidgcet is offline
Vehicle: 2012 Ram 1500
Trim Level: Outdoorsman
Rep:32
davidgcet is on a distinguished road
bad switch, either the passenger switch or the driver's side window lock switch?
Old 09-02-2013, 12:57 AM
Soul Killa's Avatar
Soul Killa Soul Killa is offline
Vehicle: 2003 Dodge Ram SLT
Trim Level: Beast Mode
Rep:12
Soul Killa is on a distinguished road
I have the same issue, i guess we might have to replace it..
Old 09-13-2013, 05:35 PM
kmdracer's Avatar
kmdracer kmdracer is offline
Vehicle: 03 Ram QC , 08 CSRT4
Rep:43
kmdracer is on a distinguished road
Mine does it randomly. Haven't been bothered by it enough yet to figure it out. If someone does, please post it up.
Old 09-23-2013, 11:32 PM
Dodgey Dodgey is online now
Vehicle: 2002 Ram 1500 4.7 v8
Color: Burgandy
Rep:55
Dodgey will become famous soon enough
Same here. It happens randomly. I rarely have passengers so it hasn't been a big priority for me.
Old 09-24-2013, 08:04 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
check the drivers side lockout switch. mines broke does the same thing.
If your willing and feel confortable. you can get the electrical schematic and test the drivers side switch and varify its bad....i have the factory manual in the 5.7 hemi section....i can help you much as i can here if you need it.
Old 01-16-2014, 03:36 PM
w110dal w110dal is offline
Vehicle: 2004 Dodge Ram 1500
Trim Level: SLT 4x4
w110dal is on a distinguished road
I have the same issue - regular cab so only the two windows, no lock feature. Replaced the passenger side switch, no dice. When it warms up a bit (Ohio and snowing), I'm going to verify all connections on the drivers side and see if that helps. If not, that's a pretty expensive part, so my infrequent passengers are going to have to deal with it
Old 01-19-2014, 11:06 PM
sealeytwin sealeytwin is offline
Vehicle: 2003 dodge ram 1500 hemi
Color: atlantic blue
sealeytwin is on a distinguished road
Default window fix
Mine was doing the same thing, had it checked out it was a broken wire. A good shop should be able to trace it down.
Old 01-29-2014, 09:43 PM
AFMEDIC's Avatar
AFMEDIC AFMEDIC is offline
Color: Maroon
Rep:18
AFMEDIC is on a distinguished road
The most common problem with the windows is broken wires in the rubber boot that connects the door to the body. I had 3 windows and 2 speakers that didn't work and it was all broken wires in the boots for the doors. The boots pull off easy but they are a pain to get back in. If you take the boot loose and see broken wires, take the door panel off and unplug all of the wires in the door, and unplug the door harness from the body, then go inside where you can sit comfortably at the kitchen table and solder all of the wires back together and heat shrink them. If you use butt connectors, they can pull free from all of the tugging on the wires. Solder and heat shrink is more low profile as well, and will protect the integrity of the repair longer than a butt connector will. I would definitely check the wires before I went throwing any money at new switches.
If Guns kill people, then pencils misspell words and spoons made Rosie O'Donnell fat...
