MY EVIC indicates the RAM is in need of an oil change. I just had an oil change 1,000 miles ago. Anyone know how to show off the message.
RansRAM 15372 posts · Joined 2010 Add to quote Only show this user #2 · May 6, 2011 Looks like they forgot to reset it. Heres what you do, Turn the ignition to "on" position but do not start the engine. Press the gas pedal all the way to the floor three times slowly within 10 seconds Message should clear. Good Luck....
G Unknown member Add to quote #3 · May 6, 2011 Yeah...if the dealer forgets to reset the counter, it will pop up at times that are not consistent with your actual change duration. I think you can turn off the reminder if you want.
