diabosport intune cooling fans
530 views 0 replies 1 participant last post by  chuckie
#1 ·
I am running the canned 91 octane tune on my 2011 R/T.
All the adustable settings :MDS . shift points, etc all seem to respond correctly
to my changes EXCEPT the cooling fan set points. The fans are running all
the time when at operating temp - which is around 203 -206 degrees with stock thermostat. The default fan settings from diablo are like 204 which explains why the fans are running alll the time. I tried raising the fan settings to 220 and they still come on at 204.... Called diablo but not much help. The fans do not run like this with factory tune. I know I could change to a 180 thermostat and the fans
will not come on but for now I wanted to see if anyone else has seen this
Thanks
