i have a 99 dodge ram with a 5.2 automatic the brake lights are out both its not the bulb cause i have a trailer brake set up and if i push my trailer brakes they work fine. its not the brake switch its been replaced... guys any ideas need help:sad::sad:
Sorry can't help you with your problem , just wanted to say WELCOME to the ForumZ! Lots of info and great people here, I'm sure someone will help you.
In the meantime, please take a moment to go on the Newbie Checkin to say hello and tell us something about you and your truck so we can all welcome you in the proper way :smileup:
Check the fuse for the brake lights and look for any loose or frayed wires coming out of the brake switch.
If not that, then you have a dead short somewhere in the circuit, probably caused by a frayed wire, up against the frame or other metal where the wire goes through the body.
Related Threads
DODGE RAM FORUM
2.2M posts
201.9K members
Since 2008
We’re the ultimate Dodge RAM forum to talk about the RAM 1500, 2500 and 3500 including the Cummins powered models.
