Old 05-14-2014, 07:52 AM
Rep:1388
Yeah I'm just saying that I don't think there's a substantial difference between an open exhaust(cutouts) vs a straight through muffler. A straight through muffler is just a perforated pipe, there's a little turbulence created(restriction) but it's very little. I'd bet(just guessing) the guys who experience faster track times or more power with the cutouts open don't have straight through mufflers. They probably have chambered mufflers which are a bit more restrictive. But I don't really know, and I doubt anyone will ever do real testing to compare as it's not worth the time/money.
Old 05-14-2014, 07:59 AM
Planert360 Planert360 is offline
Vehicle: 2013 Ram
Color: Cherry Red
Rep:54
Planert360 will become famous soon enough
But then also take into consideration the extra length of pipe, plus the bends to go up and over the axel, I cannot say if that would add much difference or not.
Old 05-14-2014, 08:08 AM
Rep:1388
That's minor. Especially if all mandrel bent.
Old 05-18-2014, 02:04 PM
Vehicle: 2013 Ram
Color: Cherry Red
Rep:54
Anyone know of a way to easily test performance (besides a dyno)? Ill be ordering a mufflex muffler delete, and was wondering if there was a way to test the truck before and after. I know a few dead highways in the area so I could use the same chunk of road for both tests. I was thinking the Android app Torque, and using the record feature, Figured it could give a rough estimate. Would be interested to see kind of how much a difference just the muffler would do, if any. Obviously a dyno would be ideal, but Im not wasting money on that. Im just looking for ball park here.
Old 05-18-2014, 09:30 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
when I thought up my exhaust system i wanted to do big pipes (and I did)...but, I was worried about it being too open that it would affect scavenging and exhaust pulses.. So what I did was run 3" piping from the header collectors all the way to the muffler which is a dual 3" in/single 3.5" out...because i was worried about the bigger flow characteristics I decided to to do the single out (turned my muffler 180 degrees)...I also added an H pipe where normally the Y pipe would be (again, to help balance the pulses)...now, this works for me because of the other mods I have so I really wouldn't suggest it unless your cammed and running headers..
Old 06-04-2014, 02:46 PM
5.7L Paramedic's Avatar
5.7L Paramedic 5.7L Paramedic is offline
Vehicle: 2017 Ram Big Horn Crew cab
Trim Level: BigHorn 4x4 Crew
Color: Granite
5.7L Paramedic is on a distinguished road
So with all this talk about back pressure, velocity etc.... I'd like to bring up a worry i have regarding valves since they are affected by back pressures. I might be getting off subject here, but would these pressures effect your valves enough to stay with certain exhaust systems. I myself, am thinking of deleting my factory muffler, adding a Y pipe, but keeping the resonators on towards the end of my exhaust. I have small strait through resonators on my 14' Ram. I'd like to have the loudness of the strait pipe but drown out the raspiness of the exhaust with the resonators. Do you think this would effect my valves in the long run.
If you can't dodge it
RAM IT
Old 06-04-2014, 07:52 PM
Vehicle: 2013 Ram
Color: Cherry Red
Rep:54
I guess I don't haveenough knowledge on the internal workings of the motors to understand how's back pressure and velocity would negatively affect the Valves? can't say that I've heard of any issues, Then again I'mnot a certified mechanic
Old 06-04-2014, 09:09 PM
Rep:1388
why do you say they effect the valves?
