Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 3.7L PowerTech V6 Specific Topics
Old 06-20-2014, 12:50 PM
J C Smith's Avatar
J C Smith J C Smith is offline
Vehicle: 2005 Dodge Ram 1500 2dr, LWB
Color: Mineral Gray Metallic
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
J C Smith is on a distinguished road
Default coil pack test
I have P0302 code on a 3.7. Is there a way to test coil without switching it to another cylinder. Like with a DVOM? It sure would be nice.
Chris
As you slide down the bannister of Life , may the splinters point in the right direction
Old 06-22-2014, 06:11 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
A scan tool should be able to tell which cylinder has the bad coil. I guess, you could confirm it by switching to another cylinder.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 06-24-2014, 03:28 AM
thunderhawk's Avatar
thunderhawk thunderhawk is offline
Vehicle: 2005 Dodge Ram 1500 QC
Rep:6
thunderhawk is an unknown quantity at this point
well he said P302 so that's Cylinder 2 but yes OHMS Resistance test on coil can be done to determine if its bad but not sure what OHMS Are suppost to be my book does not specify what its suppost to be id do the Cylinder swap and see if it moves to the Cylinder its moved too. I had a P0301 Code So Im Doing The Same thing to see if it moves if not it could be a plug or the Injector Or My Worst fear Headgasket on that Cylinder I hope not
Old 06-26-2014, 09:49 AM
J C Smith's Avatar
hydrex, it is number 2 coil.
thunderhawk, yeah I thought it might be able to be tested. Probably could compare it to a good one.
Well as it turned out , the coil was heat damaged near the bottom rubber and the glue was melted and gone. It was obvious compared to the others, so I put a new coil pack on cylinder 2 and it runs fine. Glad it wasn't an injector. New NGK plugs as well.
As I was putting new plugs and coils back on I noticed #1 and #3 coils had two faint splits in the plastic that I can only attribute to heat as well. Have to replace those in the near future.
Thanks for the replies and thunderhawk, good luck on your diagnosis.
Chris
