Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 03-07-2014, 02:48 PM
BigRam73's Avatar
BigRam73 BigRam73 is offline
Vehicle: 2006 Dodge Ram
BigRam73 is on a distinguished road
Default Water leaking in to rear storage under seat!
I have an 06 SLT quad cab and every time it rains I get water under the rear seat. I've siliconed the 3rd brake light cause I heard that couldv'e been the issue but its still leaking from somewhere. Any help would be appreciated! Thanks!!
I may get lost...but I won't get stuck
Old 03-07-2014, 03:03 PM
anothernewb's Avatar
anothernewb anothernewb is offline
Vehicle: 2013 Laramie Crew Cab
Color: Dark Cherry
Rep:168
anothernewb has a spectacular aura aboutanothernewb has a spectacular aura about
Assuming you have looked at the simple things, and there's nothing obvious like accident repair to deal with. I'd start looking at window or door seals. I suppose it's possible that the silicone didn't seal well either.
Not sure if this is a real big help, but if it were mine, I'd do it the "simplest" way. pull the seat and remove/fold back the carpet. pull all the trim you can get at till you can see all the window and door seals easily. run the truck to a car wash or get a hose and see if you can see where it's leaking from.
another long shot - is there an aftermarket stereo, or has there ever been one? IF someone mounted an amp board back there behind the sat - maybe one of the screws is punched through both layers of sheet metal and is leaking?
Livin life one truck payment at a time.
Old 03-27-2014, 02:29 PM
BigRam73's Avatar
Finally was able to find the leak...It was leaking across the bottom of the sliding rear glass. Put some silicone around the bottom to keep the water from settling in the seam and it seems to be working. Can't use the sliding glass now but better than having a pool under the back seat! Thanks for the help
Old 03-27-2014, 09:04 PM
cableman cableman is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: laramie
Color: mineral gray metalic
Rep:32
cableman is on a distinguished road
I have the power back window heres what i found. All leaking was on the drivers side. My sun roof needed to be adjusted, there was an 1/8th" gap! Then the drain tube would fill and not let water out, just had to snip it a little! Thought that was all of it till i noticed the carpet was still a tad damp after it rained heavy. Finally saw the water drops coming down in between the sheetmetal on the bottom of the window as i was spraying the outside corner with a hose! Got me some flowable silicone and that did it, not a single leak back there!
Old 06-07-2014, 02:27 PM
KelseytheDodgeGirl's Avatar
KelseytheDodgeGirl KelseytheDodgeGirl is offline
Vehicle: 2002 Ram 1500 Reg Cab 2WD
Rep:138
KelseytheDodgeGirl will become famous soon enoughKelseytheDodgeGirl will become famous soon enough
Bumpin it up for the Newbies!
Same problem in my '06 Laramie, definitely will be trying some silicone for the issue.
Go Dodge!
1996 Dodge Ram 1500 Laramie 5.2L V8 "The Beast"
2002 Dodge Ram 1500 ST 4.7L V8 "Silver" Build thread
2006 Dodge Ram 1500 Laramie 5.7L V8 Hemi
Old 06-07-2014, 03:54 PM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
Glad that you found the problem. I know that it can be very frustrating. I had a truck that randomly leaked for years... I tried everything, including a smoke test, but could never find the source.
MODS: Magnaflow Cat-Back Exhaust, aFe Stage II CAI, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Aries Stealth Bull Bar, & KC SlimLites.
Old 06-07-2014, 04:20 PM
djorko djorko is offline
Color: grey
djorko is on a distinguished road
Can you use the power sliding mirror after your sealing method? I really like that little option
Old 01-03-2015, 12:17 AM
onsomenextsht onsomenextsht is offline
Vehicle: 2006 dodge ram 2500 hd
Color: black and red
onsomenextsht is on a distinguished road
check the third brake light ..most likely that is where the leak is . i have had the same problem on a previous truck 08 1500 ram there is a write up on it on the forum
Old 02-14-2015, 05:57 PM
slowdog slowdog is offline
Vehicle: 2007 Ram QC1500 5.7 HEMI
Color: Inferno Red
slowdog is on a distinguished road
My 2007 was leaking through the bottom of the sliding window. I read that there are drain holes that drain small amounts of water from inside the interior channel to the outside of the cab. I could not locate them but thanks to Cableguy I found my drain tubes. The drain tubes are 6.5" from the outside lower corner of the rear glass (not the sliding part but the whole real window). I never saw them from inside as they begin under the black cable guide inside the bottom tract and exit too far up under the rear glass to see. I took my air compressor and blew down past the cable guide and some trash blew out the rear of the cab. They now drain, however they do not drain quickly enough to handle any significant leaks.
On my Ram the seal or window sweep at the bottom of the sliding glass has shrunk and allows water past the sliding window into the bottom channel....causing a significant leak I was unable to locate replacement seals or sweeps and no one on the forum seemed to know where to purchase the seal or sweep (as they are called) so I had to simply seal the window with silicone....making it useless....what a shame!!! I really liked that rear window!
Apparently, you can purchase the entire lower channel which is said to include the seal or window sweep...but as I recall it is said to be very difficult to install. You can go here to order it:
http://moparonlineparts.com/repair-p...lower-channel/
EDIT: I just tried the above link and you have to input your year and model and search "lower channel" it is part #3 on the diagram and cost about $94. Still, I am unsure as to whether the window sweep is included....sometime in the past I read that it was included.
I am still amazed that the rubber window sweep cannot be purchased individually somewhere as I am sure that Dodge or what ever company made these windows uses some standard window sweep... I think that if I had a strip of that sweep I could pull the old one out and press the new one into the channel...at least it would be worth a try!!
Old 02-14-2015, 06:22 PM
dig dig is offline
Vehicle: 2010 1500 Dodge Ram Crew Cab
Trim Level: SLT- Big Horn
Rep:25
dig is on a distinguished road
Default Leak
I have to tell you about a leak that my son had in his Grand Jeep. He had some hail damage and it was at the body shop, they had it setting out side and it had rained. I was looking at it and I saw that the spare tire compartment was full of water, He did not keep a spare, Now this is a college student. We looked all over for the leak, I told my son about it, he said oh no. I said what, they where to a pitt football game and the spare compartment makes a very good beer cooler. I took it home and drilled a hole in the bottom.
