What might be involved in changing the control for the passenger window to be like the driver's side in that it is click to go down without holding it? Is it as simple as changing out the switch itself or will I need to look into a modification of the motor itself?
What year do you have? If ya fill out your UserCP, it'd make answering questions like this easier. I know for the '07 you can only get switch blocks, not individual switches, so making this kind of swap is extremely difficult.
I was just going to post this question since my passenger front window switch seems to work at it's own descretion. Is it an easy change of the switch only or is there more involved?
Chances are its your drivers switch module (the bank of switches on the drivers door). My passenger and back window switches used to work at their own discretion only, until the drivers switch only pulled the window down, and took an act of congress to get it back up. I changed out the drivers bank of switches and all switches work normally now. After researching a bit about my lock problem, apparently everything runs through that drivers module and when that malfunctions, it causes everything else to act wacky.
interesting - my passenger side window switch is also somewhat intermittent, and I thought maybe some water had gotten down in there and corroded the contacts. Now I will have to pull apart the drivers side door first...how much was that part, and did you have to get it from a dodge dealership or were you able to find it at a local parts store?
Related Threads
DODGE RAM FORUM
2.2M posts
201.9K members
Since 2008
We’re the ultimate Dodge RAM forum to talk about the RAM 1500, 2500 and 3500 including the Cummins powered models.
