Ok this is going to be a little painfull.
2003 ram 1500, have no power to anything without the key in. when key is on have power to the locks at every door only if driverside door is closed, no power window work except the drivers door swithces, no accessories work either way(key on or off) accessories as in radio, obd terminal, cig lighter, but I do get interior lights then. cabin lights do not work at all unless key is on. I have tapped into the fuse panel as a temp fix for the radio and cig lighter. I like most am not the strongest in electrical. Not too sure where to start (ignition switch, intrament cluster, and or each swith windows locks lights) Any ideas?
