All I have a 2006 Ram, I just got done installing a Xenon Kit into my Fog Lights and my Headlights. I got a 35watt ballast for fog and a 55watt for headlights. When the truck is off I can turn on the lights with no problem FOG and Headlights turn on and stay on. If the truck is on the headlights Flash a couple times and turn OFF. the fogs stay on. Does anyone know what I can do to correct the issue
you need a relay harness, pretty cheap i payed 20 for mine, if you good with electrical you can wire one up yerself. the hids need a constant power source so the relay harness runs directly from the battery. the factory harness shoot power every few seconds for a feedback to the computer i believe..
i agree i installed mine and they did the same thing. i ordered a relay from the company. it was alot easier than making your own and figuring out what wire goes where. good luck :smileup:
