Old 01-06-2012, 07:44 PM
DDT4U's Avatar
DDT4U DDT4U is offline
Vehicle: 2016 Ram 1500 express 5.7
DDT4U is on a distinguished road
I think after dropping it and tinting the windows , this is going to be Mod #1
Old 02-20-2012, 07:33 PM
Ot-Of-Here Ot-Of-Here is offline
Vehicle: 2012
Trim Level: 1500 Express
Color: Cherry Red
Ot-Of-Here is on a distinguished road
Default Functional Ram Air Hood
Ck this out at:
www.suncoastcreations.com
It is for 09-11 which will include our 2012s. It has louvers down the middle and twin scoops similar to hoods I've seen on some Lightnings.
2012 Hemi Express 4X4 sb Auto
Old 02-23-2012, 01:14 PM
2012ram 2012ram is offline
Vehicle: 2012 ram sport 1500 quad cab
Color: Dark cherry red pearl
2012ram is on a distinguished road
FYI i am working on a functional kit for the hood (work in motion)working out the bugs cant give out much more info big money comp (((steal)))
Old 02-23-2012, 02:16 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The express has the same 6 speed transmission as the other Ram 1500's (which is also the same as the prior "5 speed" just renamed).
The "sport" hood will fit on the express. I don't know that you can order it that way from the factory, but it will bolt on if you buy it separate. It is non functional, just FYI. It's purely cosmetic.
I'm sure bigger brakes would fit...I think there are "big brake" kits, for a lot of money though.
Look into RIPP superchargers, they have a kit for the new rams that is very safe, and basically doesn't change anything as far as throwing codes/engine lights, etc. I would guess MDS still works with their kit, but don't know for sure.
I would also suggest getting 3.92 and LSD from the factory, it's cheap oem, but very expensive aftermarket. Also, the "trailer brake controller" option (I think like $300) will also get you the EVIC display on the dash which has oil temp, coolant temp, tire pressure monitor, trans temp, mpg, etc.... well worth the money, I'd recommend getting that as well.
Sean
Old 02-23-2012, 02:18 PM
snrusnak's Avatar
Rep:1385
It would be very difficult, expensive, and time consuming to make the sport hood functional as it has the reinforcing cross members right in the way of the scoops...
Sean
6 speed transmission, brakes, power hoood, r/t, supercharger
