Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram MPG Zone
Old 12-25-2011, 02:34 AM
FlashSmith101's Avatar
FlashSmith101 FlashSmith101 is offline
Vehicle: 2009 Dodge Ram 1500 Sport Hemi
Color: Electric Blue
Rep:23
FlashSmith101 is on a distinguished road
Default MPG problem!
i noticed today driving back to houston from austin that even on cruise control 65 to about 70 i was only getting 15.5 max MPG....that can't be good at allll right? i do have 24in rims and i am running my diablo predator sport on 93 octane race mode...is this bad?? someone mentioned i might need to spark plugs.
any ideas would be appreciated!!!
Mods- Diable Predator Sport (set on 91 octane), Air Raid CAI, Aero Turbine exhaust, 24in Boss Motorsport rims (painted white), Cut back springs(leveled), color matching blue dash and features, white emblems and grille, 180 t stat, P.A. system, all LED lights.
Old 12-25-2011, 02:36 AM
Rep:23
if someone could move this to a better suited category...i think i put it in the wrong one sowwy
Old 12-25-2011, 08:50 PM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
Is this a change in your mpg?...suddenly or over time? If you have 24" rims, are you tires taller too or are they the short style, and the combo mimics your stock height? Does your tuner allow you to recalibrate the tire/wheel height?
Old 12-25-2011, 09:28 PM
5pt7art 5pt7art is offline
Vehicle: 2011 dodge ram 1500
Rep:51
5pt7art will become famous soon enough
the rims have to have some effect on it....i drove up to shiner texas from mcallen texas and got 19mpg going 80 on cruise control....on 11 hem ram
2011 ram express HEMI RCSB
mods: vararam airgrabber....magnaflow 12588
future mods: magnaflow y pipe....v6 efan.....hemifever diablo...circle d conveter
Old 12-31-2011, 02:46 PM
Shadow634618 Shadow634618 is offline
Vehicle: 2004 Dodge Ram
Color: Gray
Shadow634618 is on a distinguished road
If you don't have a need for the 93 tune then don't use it. I can't speak for the Diablo tunners, but Superchips tunners increase your shift points when you put the higher performance settings on. Try putting the factory shift points on if you insist on the 93. Your tuner should also alow you to calibrate the larger tires and rims. Also check all your basic maintenance i.e. air filter, plugs, etc.
Old 12-31-2011, 11:28 PM
bigred0311's Avatar
bigred0311 bigred0311 is offline
Vehicle: 2010 Ram Crew Cab 2wd
Trim Level: Big Horn Edition
Color: Off White
Rep:50
bigred0311 will become famous soon enough
i have the u7137 dsp and with the new update you can adjust your tire/rim size, this will have a huge effect on your mpg. also if your are not running 93 octane with your perf. 93 tune then you need to go back to the 91 oct tune. you CAN run a higher fuel on a lower tune, but not a HIGHER tune with a lower fuel. hope this helps.
My Build Thread- http://ramforumz.com/showthread.php?p=781468#post781468
