Old 12-30-2011, 07:40 PM
Laramie Longhorn Kid's Avatar
Laramie Longhorn Kid Laramie Longhorn Kid is offline
Vehicle: 2011 Dodge Ram
Trim Level: Laramie Longhorn
Color: Cherry Red Pearl
Laramie Longhorn Kid is on a distinguished road
Default Led underhood light
I've been trying to replace the light under the hood with an led bulb but I can't figure out how to. Anyone done this successfully? How do I access the bulb?
Old 12-30-2011, 08:42 PM
LC Hauler's Avatar
LC Hauler LC Hauler is offline
Vehicle: 2014 Ram 2500 Laramie
Color: Bright Metalic Grey
Rep:72
LC Hauler will become famous soon enough
i just ordered my hood light so when I go pick it up I can see if it accessable.
Old 12-31-2011, 01:52 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
The whole fixture swings on a plastic hinge (which is bolted to the hood). You should find a latch on one of the long sides of the light that releases the fixture and allows it to swing down. Then you can wrestle with the hood liner a bit to get the fixture unplugged. That should allow you to free the lense (it comes straight off the black body). You'll need a looped festoon LED bulb if you're looking for a drop-in replacement. I think I did a write-up when I modified my '09 with an LED panel. I'll see if I can find the link for you in case you want to go with 9-12 SMD's rather than just 3-5.
Here's the link:
http://ramforumz.com/showthread.php?...ight=underhood
