Old 12-31-2011, 04:27 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:910
Exclamation Gas Cap Loose light on
Any idea what makes this light come on? i thought there was some sort of pressure sensor or something like that...
mine is on, and I have checked, rechecked, tightened AND removed and put back on the gas cap, THEN filled the tank and put the cap back on, but the light will not go out...
Old 12-31-2011, 04:37 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
mine did the same, i've removed and put back on the gas cap, the light stayed on but after a while it went away
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 12-31-2011, 10:39 PM
Holleywud's Avatar
Holleywud Holleywud is offline
Color: Austin Tan Pearl
Holleywud is on a distinguished road
It takes a while for the system to retest itself. You could use a scantool to clear the code (if it has one, would likely be described as a very small evap leak) and it should turn off the light. Otherwise, you will have to wait. Make sure that you inspect the O-ring on the gas cap and make sure that it doesn't have any tears in it.
Old 01-01-2012, 12:51 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
If it really bugs you and you're still under warranty you can go to the dealer and have it reset with their scan tool. Otherwise, like mentioned above, the system will reset itself with 4-5 successful starts (coupled with runs of 5-10 min., I believe).
Old 01-01-2012, 12:59 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3944
You didn't get the gas cap on right so it triggers the sensor. I have done that a few times. You just need to re-screw that cap back on and it will go out. For the Nitro it is 3 clicks.
Old 01-01-2012, 01:09 PM
Rep:4072
Yep, after a few key cycles, the light should go off and as suggested, I'd check your gas cap and make sure it seals. I've also heard filling up with the engine running will also cause the same code.
Old 01-01-2012, 01:16 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
with all of the above.
It takes a few start/run cycles (normal driving) for the system to be satisfied that the problem has been fixed.
If the problem does NOT go away, then there may be an issue with the upper vent hose on the filler pipe. This is NOT very common, but is a condition that would simulate a loose gas cap.
brad
Interested in one of my mods?
Old 01-01-2012, 01:21 PM
Rep:910
awesome thanks guys. ill be headed out soon to grab a coffee before i plant myself in front of the tv for football...ill let you know if it goes out.
i did check the seal around the cap and even wiped inside the filler spout. it was kinda grungy...prolly my rustproofing over spray...but ill report back if it goes away.
Old 01-11-2012, 11:55 PM
Rep:910
well it has been a while now, and the light is still on...obviously a problem. ill be trying to take her in to the stealership this week...thank god i still have a warranty!!
Old 01-12-2012, 12:19 AM
moparornocar72's Avatar
Rep:630
The light is triggered by lack of pressure built up once the pump is activated, if the pressure it low or struggling it will pop a light.
14.268 @ 95 MPH Full Trim
