Old 12-31-2011, 08:39 PM
blue beast's Avatar
blue beast blue beast is offline
Vehicle: 2011 dodge ram
Trim Level: express
Color: blue
blue beast is on a distinguished road
Default 2nd prime
ok why is the third called 2nd prime, to me its just a short third? just wondering thanks.
Old 01-02-2012, 03:04 AM
Dodge891's Avatar
Dodge891 Dodge891 is offline
Vehicle: 2001 dodge ram
Trim Level: Single cab short bed
Color: Vader Black
Rep:48
Dodge891 is on a distinguished road
thats how i always heard of it as well if anyone does know that would be a nice topic and why is it caleld that
Sparky says RAM IT
Old 01-02-2012, 11:18 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
'2nd Prime' sounds better than 'Short 3rd'
Although it's a small step from 2nd, it is usable and under certain circumstances, useful.
Because of this small step, I'm sure they were reluctant to include it in the step sequence as a 'real' gear until pressure came from the Marketing departing to have a 6 speed trans.
Personally, I find it rather amazing that in this day and age we have a transmission with 6 speeds and the bottom 4 gears are not spaced better. May be this the result of a new breed of engineers that have come from the early 'video game for entertainment' era......but that is such a cynical thought.
brad
Interested in one of my mods?
Old 01-02-2012, 01:55 PM
FrostKing's Avatar
FrostKing FrostKing is offline
Vehicle: 2003 Dodge Ram
Color: Graphite
Rep:21
FrostKing is on a distinguished road
Our truck transmissions are still a 40 yr old 3-speed automatic with two over-drives, hence the poor gear spacing.
2014 White Crew Sport 4x4 8-speed 3.92 gear
Sold: 2003 RCSB 2WD
6.4L Hemi - Turbocharged, Alcohol, Nitrous
Old 01-02-2012, 02:14 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
2nd prime is utilized as a passing gear....in most cases your trans wont downshift to 2nd for passing....to shift to 2nd it would be letting go of 2 clutches and grabbing 2 new clutches resulting in a rpm flare up...for 2nd prime it only needs to let something go at most speeds....its also available in tow haul mode if load demands or if manually shifted you will go into 2nd prime before 3rd.....in the 2012 models it will also 2nd prime at wot upshifts also....6spd technically.....marketing ploy definitely! they should build a real 6spd where 4th or 5th is 1:1......
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 01-02-2012, 02:50 PM
brad12kx's Avatar
Rep:2581
How about an 8 speed....
4 on the bottom, 1 direct and 3 OD; all spaced to keep the Hemi in the prime power range at WOT.
In my dreams, this is offered in 2013....
brad
Old 01-03-2012, 11:50 AM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
While transmission gearing can be a little bit preferential, I found just the 4 speeds in my old '89 GM 700-R4 to be more than adequate when mated behind a decently powerful, torquey engine. I did some serious 4-wheeling and towing with that setup, and it did just fine. The tranny has a low 1st and well spaced gearing up to the 4th which was an overdrive. While the gearing performed well, that model of tranny needed some good mods to make it work well and live long, and I had those done to mine.
I know that closer spacing with more gears maintains keeping the engine in its rpm-to-power sweet spot. On a truck with a decently wide torque and power band, is this as critical? Now we're talking about 8 speeds and such, and while I agree there's benefit, is perhaps some of this being driven by marketing hoopla a bit? And I realize why semi's have many gear selections to optimize their hauling capacity and economy, but that may be a stretch of a comparison for a 1/2 ton pickup. Still, I know there's some application even then. I'm thinking sometimes that 4 or 5 gears max, designed in a more robust and stouter package would be better than 8 gears in a package where they're trying to cut weight and increase fuel economy...at least on a pickup. All the money saved in fuel economy can quickly evaporate when you get the $1500-$3000 repair bill on your whizbang 12-speed auto...LOL!
And please don't take my comments as argumentative on this issue. I just wonder sometimes...are we overdoing it? And don't get me wrong. I love more, more, and even some more when it comes to power, bells-and-whistles, and hoopla as much as anyone...LOL!
One other question, because I'm new to Dodge. I'm sure I could research this one, but the comment made here about this tranny being based on a 40 year old design...if that's true, does this mean this tranny is just a redesigned Torqueflite?
Old 01-05-2012, 04:47 PM
AllUCIsTailLights's Avatar
AllUCIsTailLights AllUCIsTailLights is offline
Vehicle: 2007 Dodge Ram
Trim Level: 1500 Big Horn
Color: patriot blue
Rep:39
AllUCIsTailLights is on a distinguished road
That would be a dream come true if so it would be the perfect time to get a 2013! ill be done paying for the one i have this year.
Old 01-06-2012, 07:22 AM
2011lilred's Avatar
2011lilred 2011lilred is offline
Vehicle: 2011 1500 & 2006 2500
Trim Level: Express &ThunderRoad
Color: Flame Red & White
Rep:15
2011lilred is on a distinguished road
While the 545RFE came from the 45RFE and one could argue the 45RFE is based on the Torqueflight family with additional planetary gears, the gear spacing issue is has nothing to do with it since the 727 uses 2.45:1 in first, 1.45 in second, and 1.00 in third while the 545RFE uses:
  • 1st 3.00:1
  • 2nd 1.67:1
  • 2nd Prime 1.50:1
  • 3rd 1.00:1
  • 4th 0.75:1
  • 5th 0.67:1
(Note the similarity to the 700R4 ratios of 3.06, 1.63, 1.00, 0.70)
If you take 2nd Prime out of the upshift sequence, the gear spacing is just fine. The whole 2nd Prime gear came about simply as a taller passing gear to avoid downshifting all the way down to the 1.67 gear when you stomp on it on the highway. As you would likely be in an overdriven gear at the time, jumping all the way down into the traditional 2nd gear causes rpms to skyrocket - again, note the similarity to the 700R4.
2nd Prime was not originally intended as an upshift gear, it just morphed into one.
RIP - 03 Hemi SLT QC; uncorrected 14.68 at 90.46 w/ 2.08 60ft - stolen July 06
Old 01-06-2012, 10:37 AM
TNC TNC is offline
Rep:12
  • 1st 3.00:1
  • 2nd 1.67:1
  • 2nd Prime 1.50:1
  • 3rd 1.00:1
  • 4th 0.75:1
  • 5th 0.67:1
Thanks for that info on the trans background and ratios. I realize that this is the drag racing forum segment, and more gear selections usually relate to better performance times/numbers.
