Old 01-02-2012, 03:22 AM
RamJD RamJD is offline
Vehicle: 1999 Ram 1500 4x4
Trim Level: SLT Laramie
Color: Green
RamJD is on a distinguished road
Default Truck won't start- fuel system issue?
I've recently been having some issues with getting my truck to start. Initially it wouldn't start in damp weather only, so I replaced the distributor cap, plugs, wires and ignition coil and it started up just fine in the rain. My truck's been starting and running fine for the past three weeks or so, but this morning it refused to start again. I know that the issue isn't the ignition system which is all brand new, or the battery which is about a year old. It'll crank just fine, but it doesn't sound feel or smell like the engine is getting any gas. My fuses are good, so I'm guessing that the problem is either with the fuel pump or somewhere in the fuel delivery system? Any help with where to look or other possibilities would be greatly appreciated. Thanks.
Old 01-02-2012, 03:38 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Verify that the 'Automatic Shut Down Relay' in the Fuse box is clicking when you turn the key on. Also, you should be able to hear the pump when you first turn the key on. It makes a 'whirring' sound for a short time as it's coming up to pressure.
brad
Interested in one of my mods?
Old 01-02-2012, 03:45 AM
Color: Green
I'll check the auto shut down relay, should I be able to hear the fuel pump from inside the cab or do I need to listen close to the gas tank? Thanks.
Old 01-02-2012, 04:01 AM
Dodge891's Avatar
Dodge891 Dodge891 is offline
Vehicle: 2001 dodge ram
Trim Level: Single cab short bed
Color: Vader Black
Rep:48
Dodge891 is on a distinguished road
check the relay and see how that works
Sparky says RAM IT
Old 01-02-2012, 06:45 AM
dnld dnld is offline
Vehicle: 1998 dodge ram 1500
Color: black and red
dnld is on a distinguished road
You should be able to hear it from the cab, however if your like me and hard of hearing then undo the gas filler cover on the tank to relieve any pressure and have someone turn the key to the run position and listen at the filler spout. Hope this helps.
Old 01-02-2012, 10:57 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Or if you can't hear it use a pressure tester once fuel rail, I think these might be like gm if there's not enough pressure at injector it won't start. It should have at 45 psi at rail.
Old 01-02-2012, 11:00 AM
ramfam's Avatar
Trim Level: Base
Rep:21
And don't be mistaken a fuel pump dsnt just go out all at once it can slowly where out and become speratic over time.
