Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 4.7L (287 cu in) PowerTech V8 Specific Topics
Old 01-12-2012, 05:18 PM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
I really don't know. I'd guess no. If it operates the same way in stock tune that is more reassuring that it is nothing computer/pcm related (at least in my mind).
The only reason the computer came to my head it because my dad installed a torque converter into his 2001 35th anniversary 5.7L Camaro. He had similar problems with the check engine light. not to sure if it was the TCC or not. When he sent his computer to be programmed he mentioned to the Tech to remove the diagnostics code, and also to add a bit of pressure to the trans to make it shift into the last gear. Apparently that did the trick. worked fine after that. But then again he never was on the highway. Much less on the road. It was almost 10 years old with 5,500 miles on it. Never saw rain. Never slept outside. Ran a 11.988 in the 1/4 mile in Edingburg.
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 01-12-2012, 05:41 PM
Color: Gloss Black
Rep:141
Old 01-12-2012, 05:43 PM
Color: Gloss Black
Rep:141
Old 01-12-2012, 07:25 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
You have a very nice looking truck! My good buddy also has a z28 (I think 01) and it runs a best of 12.9. Will run 13.0 consistently. He has a superchips tune, longtube headers and full exhaust, intake with ram air, and a couple other minor mods.
Sean
Old 01-13-2012, 09:22 AM
Color: Gloss Black
Rep:141
Thanks! Only if he would stop mis-behaving it be nice
Old 01-17-2012, 10:00 AM
Color: Gloss Black
Rep:141
Yesterday on my way home I hit cruise control at 65 mph. I believe the TCC engaged due to the fact that my Rpm's dropped (while in cruise control) to 1600 rpm. What was odd though was the fact that the needle was bouncing back and forth between 1600-1700 rpm. I thought the problem was fixed! But as soon as I made a turn and went back to 65 mph it didn't engage. Neither did it this morning
Old 01-17-2012, 10:04 AM
Color: Gloss Black
Rep:141
Not necessarily that. But the computer having to be reprogrammed to the new converter?
Old 01-17-2012, 10:07 AM
Color: Gloss Black
Rep:141
hmmm I agree what the first 2 shops said is BS. It's always recommended to replace the o ring everytime you service the converter. It's likely that maybe this is simply the issue, and you just need to replace the oring and re install... I've also been told not to use grease, even with manual transmissions, but when I did my last clutch in my old truck I used grease and didn't experience any problems. Probably best to use the vaseline though.
Old 01-17-2012, 10:35 AM
snrusnak's Avatar
Rep:1385
The computer should not need reprogrammed due to a converter change.
Sean
Old 02-21-2012, 08:56 AM
Color: Gloss Black
Rep:141
I forgot to update this post,
I solved the problem!
I Re-installed the stock converter.
