Old 01-03-2012, 12:38 AM
Jmorris Jmorris is offline
Trim Level: SLT Big Horn
Rep:25
Jmorris is on a distinguished road
Default 2,000 lbs in bed
I have a 2010 big horn 1500 4x4 5.7 with 392 gears, quad cab 6.5' bed. I am looking to pick up a pallet of heating wood pellets. i think the weight is around 2,000 lbs. I will only be driving about 5 miles through town. Is this amount of weight going to hurt anything or will i be ok.
2010 White Ram 5.7 1500 QC 4x4 Big Horn
raptor 4" tube steps, rockers linex'd, egr bug shield
Old 01-03-2012, 12:52 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Well.....don't know how to answer this.....
At 2000 Lbs, you are definitely exceeding the manufactures payload rating as well as the rear axle rating, so -
It would be against the law
If something went wrong, there could be insurance issues
If something breaks, there could be warranty issues
Me on the other hand, have done more for longer; but I understand the risks and know my Ram.
brad
Interested in one of my mods?
Old 01-03-2012, 01:27 AM
Rep:2657
For a short trip & driving carefully, a 2,000 pound load won't hurt a thing
If you did it often, you ought to think about borrowing a trailer
your only 400 pounds over the recommended haul weight
Old 01-03-2012, 10:54 AM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
I live in an area where it appears that 50% of all vehicles on the road are pickups. There is a large amount of livestock, agricultural, and oil field activity. The trucks I'm referring to get used for their intended purpose. Many friends and neighbors constantly tow or haul loads that exceed the recommended level for short distances. Many of these trucks get used until they just about turn to rust, and they look it...LOL! Being a gearhead, I've always kind of paid attention to how they hold up. Oddly, it seems most pickups hold up to this kind of abuse for these short distances. I see hardly any of them doing any long distance hauling/towing in this manner. It seems there's a level of "cushion" built into most trucks to handle without absolute failure. I'm with GTY on this when it comes to personal use and just use one of my trailers and don't overload...but I hate to abuse machinery too much.
On another note, in my area the Dodge diesel seems to be the clear winner for 3/4 and 1 ton trucks, and the Chevy seems to be the popular 1/2 ton pickup. There are more ancient and new pickups of those two brands than you can shake a stick at.
As brad rightly points out, it can be a safety issue and especially concerning the braking. Some nimrods get into their truck when heavily loaded and drive it like the family car. Potential damage or not to the mechanical components in the truck, it won't stop that well, so give yourself a big fudge factor for stopping distance, even if you're just going around the block.
Old 01-09-2012, 05:12 AM
Rep:25
thanks for the replys. after thinking about it for a couple of days i think since im so close im going to split it into 2 loads. I know the truck could probable handle it but its my only vehicle and my luck is that something would happen. so thanks again
Old 01-16-2012, 09:41 PM
UPANDCUMMER UPANDCUMMER is offline
Vehicle: 12 Ram 3500 6.7L Mega 4x4 SRW
Color: Mineral Gray
UPANDCUMMER is on a distinguished road
That's why I bought a 1 ton, I can pretty much haul what ever I want. Also, why I bought a 5 ton trailer...
Old 01-17-2012, 10:54 PM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
with the coil springs in the rear the truck will just bottom out and blow the shocks. i tried to haul a pallet of pavers and when the forklift dropped it down the truck just kept sinking. i had to split the load so will you, if you had leaf springs they would eventually stop bending.
Too many mods to fit here!
Old 01-26-2012, 10:20 AM
rcgreg rcgreg is offline
Vehicle: 2012 Longhorn
Trim Level: longhorn
Color: Black/gold trim
rcgreg is on a distinguished road
A more important consideration - is your tires. Generally you would need 10 ply rated tires for that kind of a load, if your tires are rated lower - you can still manage - but you need to be aware that you will experience more 'sway' and the possibility of tire failure. So pick a route where getting off the road would not be a problem.
Old 02-02-2012, 09:13 PM
welr welr is offline
Vehicle: 2011 Dodge Ram
Color: Gray / Sandstone
welr is on a distinguished road
RCGREG is right about the tires. Tried hauling a 2,000 pound slide in camper on my last 3/4 ton. Truck was all over the road with D load range tires. Took up grading to E's and heavier shocks and airbags to make it work right. I've hauled a ton on a half ton .... won't do it again.
Old 02-02-2012, 10:24 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Brad said it right. I had 1800lbs in the bed of my ram from Syracuse NY to Seattle WA. Not a problem...but I knew what I was doing, and my tires were rated for it.
If you arent comfortable doing it, then split it. I didnt really have a choice, I was paid by weight.
Yeah, but not everyone has 60k+ to drop on a Loaded 1 ton!
A few miles wont blow his shocks, I hauled 200 lbs less for 3200 miles without a single issue. I just had to get some 10 ply's tires for the rear end. I bought them, put them on, got here, sold them and got almost what I paid.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
