Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 07-10-2013, 10:54 PM
Brutus's Avatar
Brutus Brutus is offline
Vehicle: 2006 Dodge Ram
Trim Level: 4x4 Quad Cab Sport
Color: Mineral Gray
Rep:86
Brutus will become famous soon enough
I know this topic over a year old, but has anyone come up with a solution to this?
My 2006 has this problem. If I give it one pump it's all good till the next stop. I bled them and they were good for a week or so.
2006 Hemi Ram QC 4x4
2000 AF RC Dak R/T
2000 BW CC Dak R/T
Old 07-11-2013, 12:05 AM
highlander highlander is offline
highlander is on a distinguished road
Had similar issues as described in above posts. Soft feel and a lot of fade, almost ran into the back of a van that stopped quick to avoid hitting a deer. Not safe. Took it home and popped the tire off to find the front pads had so much rust built up on the sliders they couldn't move freely and actually needed a hammer and coal chisel to get them off. The pads were also more than half worn and the rotors were looking nasty.
So the order went in for all new front and rear rotors and pads along with new park brake shoes and hardware. My ram has 85000 Km's on it(53000 miles). Got a sweet deal on a full set of Powerstop drilled and slotted rotors and ceramic pads (k2164). It is the heavy duty towing kit, comes with new clips and descent instructions for installation and break in.
Glad I got the whole set as the rear rotors pads and park brake components were just as bad as the front. The park brake liners fell off when I pulled the rear rotors off(!). Surprised I could stop at all really. I should mention that I only haul my atv and mulch and the like in the bed, no heavy towing. But with a 6" lift installed and 37's on the near horizon I wanted better stopping power.
Anyway, got it all installed and run in and to say I am very impressed would be an understatement! It has never stopped or felt so crisp and responsive when on the fat pedal. It really worked well for me.
Old 01-26-2014, 11:41 AM
smithc7589 smithc7589 is offline
Vehicle: 2010 dodge ram
Trim Level: trx4
smithc7589 is on a distinguished road
I replaced 3 out of 4 calipers and the master Cylinder bled them until the fluid shot across to the other tire if I pump it up 4 times I have pressure at that time but if I start moving I loose it again. If I disconnect the vacuum hose I have pressure but ever since I change the calipers I havent had the same pressure how do I fix it?
Old 01-30-2014, 09:38 AM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
subscribed................
Old 02-01-2014, 05:22 PM
empress empress is offline
Trim Level: Laramie 4x4
Color: grey
Rep:15
empress is on a distinguished road
Default soft brake peddle
Had the same problem soft brake peddle until I moved the peddles off the there bottom setting. When the adjustable peddles are adjusted as far away from the seats then I have to pump the peddle to get away from the softness. As long as I have the peddles up a little they work fine. The brakes are new just replaced.
Hope this helps some of you cheers Gary
Old 02-16-2014, 03:04 PM
ric221's Avatar
ric221 ric221 is offline
Color: PR4 Flame Red
ric221 is on a distinguished road
just one of those things Dodge thought we needed to work with.
Old 03-02-2014, 01:35 AM
hapamoto hapamoto is offline
Vehicle: 2010 ram 1500 4x4
Trim Level: onehalfjap@aol.com
Color: onehalfjap@aol.com
hapamoto is on a distinguished road
I changed out my front calipers and rotors with the SSBC 4 piston calipers and oversized rotors and it feels like I could rip the front end off when I hit the brakes now. The best improvement yet. I hope to find some SS brake lines soon and that should help some more. When I first put on the kit I used the pads that came with it and had a nasty low speed squeak so I swapped out the pads with some Wagner thermoquiets ceramics and it still stops great but no squeak.
Just do it you will love it!
Old 03-02-2014, 09:43 AM
ShotCaller's Avatar
ShotCaller ShotCaller is offline
Vehicle: 2014 Ram 4x4 Bighorn
Color: red
ShotCaller is on a distinguished road
I had a new 2012 ram. After about 2000 miles the brake pedal would go all they the way to the floor before it would stop the truck . I took it back to the dealer and they said it was normal.
I even had them compare it to a new one sitting on the lot and they still insisted it was normal.
I got rid of that truck because I never felt confident in the brakes.
I have a 2014 ram now....the brakes are 100% better.
Old 03-02-2014, 12:34 PM
Slitherbeast Slitherbeast is offline
Vehicle: 2010 Dodge Ram 1500 Laramie
Color: Brilliant Black Pearl Clearcoat
Rep:18
Slitherbeast is on a distinguished road
There is no substitute to properly bled brake lines! if the pedal is mushy and gets better when you pump them, There is air it the lines somewhere!.
Old 09-21-2014, 10:03 AM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
In my case, same 'softness' before and after bleed/fluid replacement. 68k miles, all OEM.
I do have the pedal on the very 'bottom' setting,,, will experiment with that next.
