tonneaucovered.com
Old 01-03-2012, 10:39 AM
TarisKellog TarisKellog is offline
Vehicle: BetterThanYours
Trim Level: TheBest
Color: TheBest
Rep:44
TarisKellog is on a distinguished road
Default Truck Condom aka paint protection film
I purchased clear paint protection film to cover the front hood (up about 12"), front bumper, headlights, tailgate, and sides up 18". Film is made by 3m and has a 5 year warranty. Total cost of film $630. The front pieces came pre-cut whereas I ordered bulk pieces for the sides and tailgate. On the bulk film I had to cut out areas for badges and tailgate handle. Also, had to cut to fit each door and area in front of rear wheel.
Started on the truck condom install this past weekend. Have been waiting for warm days to do the install, and looks like mid 40's was as good as I was gonna get. Tools I used were the smoothing yellow tool, towel, hair dryer, small scissors for trimming, tape measure, spray bottle filled with alcohol/water solution, and lots of patience.
Day 1 - Installed the front first.
Day 2 - Installed the tailgate and 3/4 of driver side
Driver side completed on gold two-tone color. 4 pieces total. Will be adding another 6" to the bottom of the green color.
Waiting on another sunny weekend day to finish the driver side and entire passenger side. Each day I worked on this a minimum of eight hours. Started around 29 degrees (8:30am) and would finish around 34 degrees (4:30 to 5pm). Although I was doing this all day for 2 days it didn't feel like an all day job. I really took my time and allowed my obsessive compulsion to drive me. I washed each area prior to installing since I had a bit of road grime.
Helpful hints: use lots of water/alcohol solution. The film smooths out much better when it is wet and the vehicle is wet. There is a high degree of stretchiness to the film but be careful when stretching as it may be harder to smooth edges when stretched. Use a hair dryer to heat film so it will contour to curves and to help flatten edges. Use lots of smoothing strokes to remove air bubbles. Sometimes I would smooth one area over and over and over and over. When cutting bulk film I used a quilters cutting wheel to give a smooth cut over a long distance. If you use scissors you will get a jagged cut and it will not smooth as nice. Scissors are good for detail trimming only.
When installing the front hood I found it easier to start in the middle and smooth outwards. When installing the tailgate and sides I found it easy to start at the top all the way across and work down.
Any questions about specifics just message me.
Old 01-03-2012, 12:02 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1276
After seeing some of the swirl marks and rock chips on my Ram I wish I would have done this to my Sport. Oh well next time. Nice job on yours!
Big Red my old 2011 Sport
Old 01-06-2012, 05:36 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Very nice! That takes a lot of time but you'll be happy in 5 years when the paint is still perfect!
I have some question if you don't mind as I want to add this in some areas of mine:
Where did you buy the stuff?
Is it really "invisible", or can you see it, can you see the edges?
Did you fold the ends around the lip of the panels?
Do you know if it just peels off if you want to remove it in the future, or is there any problems with it like leaving a line in the paint or anything if you remove it?
Thanks for any help!
Sean
Old 01-09-2012, 10:00 AM
Trim Level: TheBest
Color: TheBest
Rep:44
Hi Sean,
I purchased all the film on ebay from a vendor called Clear Defender. I highly recommend them as they have great customer service and good pricing. I initially made an offer on the deluxe front protection. It was listed for $249 and I offered $204.95. I also added in my offer that I wanted to purchase the headlight kit and bulk film for the tailgate and sides. They accepted my $204.95 offer for the front, sold the headlight kit for $50 (listed for $56) and the bulk pieces were $113.36 for both sides - each measuring 18" x 108", and the tailgate was $99.41 measuring 24" x 72". They gave me free shipping, too, and included the yellow tool. http://myworld.ebay.com/cleardefende...id=p4340.l2559
Is it invisible.....yes and no. You totally cannot see it from about 6-8 ft away, but if you are standing right next to the truck you can see it. You can see the line where the film ends, but it's not unattractive. Also, I've noticed some bubbles that I didn't quite smooth out good enough. Again, from about 6-8 ft away you can't even see the bubbles, but you can see them if you're right next to the vehicle. I'll see if I can get some pictures that will show the lines and bubbles. I'm also going to try to see if I can smooth out the bubbles when the weather gets in the 70's.
Did I fold the ends around the lips of panels....yes and no. On an area such as the doors where the door ended I cut the film to about 1/8" from where the door ended. But, where the body of the truck curved (like the end of the cab) I cut the film a little longer and tucked it in. It would be extremely difficult if you wanted to wrap the film around the edge of the door. Maybe a professional installed could do that. I had trouble with a couple of areas where there were multiple curves.
When I purchased the film they said that it could easily be removed without damaging the paint. I can say that when I would have to take a piece off to re-adjust it seemed like it was stuck really well. I was a bit worried that paint might come off, but I peeled it off slowly and it came off no problem. I don't know of any issues with it leaving a line if you take it off.
I will see if I can get some pics that will show the lines that way you can see how the pieces are cut and placed, and get a better feel of how it will look. I am more comfortable with seeing the film line than seeing chips/scratches.
Old 01-09-2012, 10:26 AM
ru223l ru223l is offline
Vehicle: 2006 Dodge Ram
ru223l is on a distinguished road
That is some awesome stuff. I co-worker bought stuff like it for his new mini cooper. He was ranting on about how awesome it was and I think he paid extra so that it wasn't uv protected. That way his hood will will fade with the rest of the car. You did a fantastic job though. From the pictures it looks like a professional did it. Congrats!
'06 1500 QC 4.7L
Old 01-09-2012, 10:02 PM
snrusnak's Avatar
Rep:1385
Thanks tariskellog for answering my questions! I plan on doing this (whether myself or paying a professional) and appreciate the info!
Sean
Old 01-30-2012, 01:18 PM
Trim Level: TheBest
Color: TheBest
Rep:44
I was finally able to get pics and edit a hot pink line in them to show where the paint protection film is to give a better idea of how it shows up.
Old 01-30-2012, 01:23 PM
snrusnak's Avatar
Rep:1385
^I can just barely notice it. Thanks for posting.
Sean
Old 01-30-2012, 04:15 PM
AutoAnything's Avatar
AutoAnything AutoAnything is offline
Your Mod Superstore!
Vehicle: Full Garage!
Rep:203
AutoAnything has a spectacular aura aboutAutoAnything has a spectacular aura aboutAutoAnything has a spectacular aura about
Well done!! Looks great...
Click the ^banner^ and save up to 16% OFF Orders Above $150 on Dodge Ram mods.
We price match, simply call 888-591-8563 or
Click-Here-to-Chat and we'll beat ANY price by $1.
Click Here To See The Latest and Greatest Specials From AutoAnything!
Old 02-04-2012, 01:42 AM
CaddyRam's Avatar
CaddyRam CaddyRam is offline
Vehicle: 2010 Ram
Trim Level: Slt Big Horn CC
Rep:12
CaddyRam is on a distinguished road
Nice. I think I'll do that to my front bumper when I paint it.
Mufflex18,limo tint,DNX 6960w/rearview camera, sirrius satellite,DVD,Nav,radar detector/video camera mount, Damplifier.Ez down tailgate assist,bed extender, LineX,relocated rearwindow switch,custom twin filter air intake,custom front/rear center consoles w10'' Kappa and LED lighting.
