Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 01-03-2012, 12:51 PM
aharris aharris is offline
Vehicle: 1997 Dodge Ram 1500
Rep:19
aharris is on a distinguished road
Default Door Handle Replacement
Hello all. Does anyone have any info, like a vid etc. of how to replace the outer handle on passengers side of 97 Ram 1500? I got the panel off, and have started to undo what looks to be holding the handle on, but one nut is very difficult to access. Also confused about removing lock linkage, etc. Thanks!
Old 01-03-2012, 01:02 PM
moparornocar72's Avatar
Rep:630
This is all I could find and i hope it helps!
EXTERIOR HANDLE
REMOVAL
  1. Remove door trim panel.
  2. Remove water dam as necessary to gain access to door handle.
  3. Roll glass up.
  4. Remove fastener access plug from door end panel.
  5. Disengage clips holding latch and lock rods to door latch.
  6. Separate latch and lock rods from door latch.
14.268 @ 95 MPH Full Trim
Old 01-03-2012, 01:21 PM
Rep:2705
This is a different year, but it may help you
Old 01-06-2012, 11:00 AM
Rep:19
Thanks guys. Both posts actually helped! I found a removable rubber plug in the door that allows access to the hard to get at nut, and the linkage was a breeze to disconnect, you just turn the plastic clips and the rods will slide right out. Door panel is going back on tonight and I should be done. Thanks again!
