MOPAR DECALS
Old 01-05-2012, 02:07 AM
seattleram seattleram is offline
seattleram is on a distinguished road
Default Gas types
I was talking to a friend today that said that putting premium (92 octane) gas in the hemi truck causes it to misfire because of the higher octane amount. Is this true? should i only put mid grade in it or is premium better?
Old 01-05-2012, 02:23 AM
Rep:2875
92 octane is a waste of money
the Ram Owners Manual reads use MID GRADE gas, 89 % for best performance
It also reads that 87 octane is also acceptable
The only time you might need to switch to a higher octane level is if your car engine knocks or pings when you use the recommended fuel
Usually the high test gas is only needed if your running a modified engine, like a Turbo or a performance cam
Old 01-05-2012, 11:38 AM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
That's a new one to me, having a 91/92/93 octane pump gas actually cause a misfire in any normal modern vehicle. I haven't seen or heard everything, but I'd like to hear the specifics about how it's supposed to happen. As to the value of the fuel in performance vs. price vs. economy, it's a debate that rages all the time. The claim for higher octane is that it will produce a small power increase because the anti-knock sensor, timing, and other computer controls will allow the engine to yield more power. There's some truth to this in very small quantity. Fuel enconomy "can" improve in some cases, but it's debateable how the price and mileage gained balance out. As an engine gets more extreme in its tune/components or at least the useage gets more extreme, the higher octane probably does yield more useable power. Under real "hotrod" or maybe even towing conditions, the higher octane fuel might be more noticeable in its value vs. performance. Here's a link about fuel octane and even octane boosters that might be interesting.
http://www.hotrod.com/techarticles/f...ng_comparison/
Old 01-05-2012, 11:47 AM
Scoooter's Avatar
Scoooter Scoooter is offline
Vehicle: 2009 Dodge Ram 1500
Scoooter is on a distinguished road
I was running 89 in my 2009 until I noticed the cylinders knock under load such as going up a hill in cruise, I've now switched back to 93. We have 87, 89 and 93 here. I don't think your friend is correct.
www.AllCyclesGroup.com
Old 01-05-2012, 12:15 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
It won't hurt anything but probably a waste of money. Run the lowest octane you can that gets no pinging and best mpg/performance.
Sean
Old 01-05-2012, 12:26 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
We run mid-grade in the Hemi Charger and the truck. Best MPG for both.
Old 01-05-2012, 01:36 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
As others have said it might be a waste of money, but I personally dont think it will hurt it any. I rarely ever run 87 in my two Hemi's, It's 89 98% of the time, To me they run better on 89. Sometimes I treat them to a tank of 93 or even add the 93 to the 89.
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
