Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-06-2012, 01:24 AM
vaichus vaichus is offline
Vehicle: 1995 dodge ram 1500 5.9l 4x4
Color: SILVER
vaichus is on a distinguished road
Default heater throws cool air; good thermostat whats next
i just changed out my thermostat because I had no heat. Thought I would start there but it did nothing. Temp gauge is working fine. No leaks on my passenger side floor. I have a chk eng lite that went on but since my truck is a 95 the auto parts store can't diagnose anything older than a 96. Anyway, I was told a few things; heater core, actuator door mechanism, and a relay under the passenger side dash. Is there a way to trouble shoot my problem before taking apart my dashboard and start replacing each of these? Oh, I should also mention this past summer I flushed the radiator system for the first time in a real long time. Just thought I'd mention it. Thanks for whatever help comes my way.
Old 01-06-2012, 01:30 AM
Rep:2890
I would look at the YouTube videos
Start with the HEATERTREATER vids
also look at the the vids that show how to clear out the heater core
Old 01-06-2012, 01:32 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
You should be able to the 3 turns (key on, key off x3). The check engine will blink so many times. Search the site for the proper procedure. Does the blower fan work? Do you hear the actuator door working?
Old 01-07-2012, 10:03 AM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
If your heater hoses are hot, then your heater isn't plugged. If the inbound is but the outbound hose is cold you've got a heater core issue.
I would guess your blend door system isn't functioning, or you've got a vacum leak or leakdown if your vacum filter/check valve is bad. That valve is in the engine compartment on the back pass side, usually by the valve cover with a mess of other lines.
Try googling dodge ram blend door.
Old 01-08-2012, 01:59 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I would check the thermal relay. It's easy to get to and located under the passenger's side of the dash. It's held in with 2-7mm screws and has a plug with 4/5 wires in it.
95 dodge ram, heat, heater core, radiator, thermostat
