Old 02-14-2013, 11:57 AM
Boubou's Avatar
Boubou Boubou is offline
Vehicle: 2010 Dodge Ram QC 4X4 Hemi
Trim Level: 4X4 SLT Hemi
Color: Light greystone
Rep:64
Boubou will become famous soon enough
Default TPMS valve stem
Wondering what the TPMS valve stem are made of on the 2010 Ram.
Wanting to increase air pressure on my Michelins LT tires bur was told I cannot increase it above 60 psi if the stems are not metal.
Are the stems metal or plastic on this model?
Old 02-14-2013, 12:00 PM
Rep:1915
That's old school thinking regarding valve stems. The TPMS sensors can handle E rated tires at 80 psi. Why would you want to go that high in a 1500? Or are we talking about a different truck?
Old 02-14-2013, 12:16 PM
Boubou's Avatar
Rep:64
I don't need to go 80 psi but want to put in 65 psi. Towing.
I had 55psi in them last summer and it towed well, but this other guy on here said Michelins should be aired up to 65 psi when towing because there could be side wall separation....
Brigitte
Old 02-14-2013, 12:17 PM
Boubou's Avatar
Rep:64
CRANKYPISTOL
Vehicle: 2011 Ram 1500
Color: Mineral Gray
I would not run more than 50 with a rubber valve. Be careful running a michelin at low (below 65psi) while loaded. They have thin soft sidewalls (for better ride) and underinflated can cause a sidewall seperation.
I work for Goodyear as a store manager! If you have any tire questions feel free to ask. If I do not know, I will find out.
Old 02-14-2013, 12:28 PM
Rep:1915
If you're going that high in pressure, I presume you've already put on a set of 8 ply tires?
Old 02-14-2013, 12:42 PM
Boubou's Avatar
Rep:64
Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi
I tow 6800 so not quite sure how much air I should put in.
Do I just calculate the weight of trailer or trailer and truck? Total combined weight is 13000
Old 02-14-2013, 02:11 PM
Rep:1915
Experiment and see what works best for you. I would start around 50 psi and work my way up.
